HP PSC 1315 All-In-One InkJet Printer Logo
Posted on Apr 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have snow leopard on mac and I cannot get hp 1315 all-in-one to print. How old is this model?
Anonymous
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Apr 20, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
23766
Points
127
Http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01664444#N30
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
3answers
CAN IT WORK WITH APPLE COMPUTER ?
Here is a list of HP Printers that works with Apple MAC http://www.hp.com/sbso/printing/mac/
if you are wondering if a specific model works with Apple,then kindly provide the model number of
that HP printer and I'll check it up for you.Thank You.
I am unable to print from my new Mac [snow leopard]
The Mac Snow Leopard has a built-in driver for the HP Photosmart C6180 all-in-one inkjet Printer. click on your system preferences under the apple at the top left of the screen, then click on Print
2answers
Olympus P-440 doesn't work with Snow Leopard. What
The first thing that you need to do is to verify if your Olympus P-440 is if it's supported by Mac OSX 10.6.x (Snow Leopard). If yes, make sure that you've installed the correct driver for Snow Leopard.
You may check the link below:
http://driverscollection.com/?file_cid=41942227668e7c7e22782bc2081
This link contains a driver for Mac OSX. I assume that this driver will work with all OSX (starting from Tiger to Snow Leopard). If this driver will not help, you may need to contact the manufacturer, and verify the system requirements of your printer.
Thank you and good luck!
1helpful
No printer driver for HP LaserJet 4ML on Mac running Snow Leopard
The drivers should be packaged into snow leopard. This printer is listed as a supported printer for Snow Leopard.
this link will walk you through the process
Hp.com
Al
[email protected]
5helpful
2answers
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
6helpful
HP Scanjet 4470c compatible with Mac OS X 10.6.1
You will not find drivers for this old scanner. Sorry but this scanner is not compatible with Tiger, Leopard, or Snow Leopard, and HP offers no drivers other than for OSx 8.0 & 9.0 which are 10 years old. Time to purchase a new scanner.
I have a Mac w/Snow Leopard. I cannot get to hp.com\support to download drivers for an Office Jet 7780. The Mac recognizes it as a printer but not as a scanner.
As from this link , the drivers for most HP printers are already built-in to Snow Leopard. Thus, they didn't recommend reinstalling driver from your HP printer CD. Here are some excerpts regarding scanning feature on Snow Leopard from the link: Scanning: The Scanning interface is now built into Snow Leopard and supported with the Apple Image Capture application. Instructions follow. NOTE: HP Scan Pro software (from Mac OS X 10.4, 10.5) is not supported in Snow Leopard. The HP icon for HP Device Manager still in the dock after upgrade is not functional and should be removed. NOTE: Scan support from pushing the Scan button on the printer is not supported with this version of the scan interface built into Snow Leopard. Scan functionality is supported by scanning directly from the computer.
** there are methods on how you can scan on Snow Leopard from the link that I've given above. But I'll paste here Method 3:
Method three: Scan from Print & Fax > Printer browser
  1. From the Apple menu, choose System Preferences .
  2. Click Print & Fax .
  3. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  4. Click the Scan tab, and then click Open Scanner . The Printer Browser window appears.
  5. Click the Scan icon at top right of the toolbar to launch scanning. The scan interface opens. Click Show Details to view settings and options.
Important Gotcha: If the Scan or Print icons do not appear in the Printer Browser window toolbar, you need to delete the current HP printer queue and add a new one, as follows:
  1. Close the Printer Browser window to return to the Print & Fax preference pane. Or, go directly to the System Preferences > Print & Fax pane.
  2. Select your HP printer in the list on the left.
  3. Click the - sign at the bottom of the list to delete the product from the list.
  4. Click the + sign at the bottom of the list to add the product back to the list.
  5. Select your HP printer, and then click Add to create a new print queue. The next time you open thePrinter Browser window, the Print and Scan icons should appear in the toolbar, providing access to Image Capture.
Need MAC Snow Leopard printer drivers for;
I had installed the Mac X snow leopard, but every time i tried to print with mi HP laserjet P1005 i have this error
P1005 i have this error Process: PrintJobMgr [416]
Path: /System/Library/Printers/Libraries/PrintJobMgr/Contents/MacOS/PrintJobMgr
Identifier: PrintJobMgr
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: cupsd [28]
I reinstalled the Hp drivers that I could find on the internet but the problem persist
52helpful
12answers
HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here : http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=us&product=374572&os=219&lang=en
I just installed the software and am now scanning problem-free.
k24674
Grand Canyon Tech
Grand Canyon Tech
