Question about Dell Inspiron 6400 Notebook
Screen dead as a dodo - and its not inverter or backlight - HELP
Hi, and thanks in advance for any assistance.
In a nutshell:
Out of warranty
Screen dead.
Video card is ok as external output to monitor works.
Have changed both the inverter, cable and backlight and still no joy.
What else could it be? How can I test inverter or backlight?
  • Sean  Hughes
    Sean Hughes Aug 07, 2008
    Cheers for reply. Cant be motherboard. There is an image on the screen itself , problem is the backlight does not light up. I have tried 2 other compatible inverters, the vid cable and changed the backlight but no joy.
    I know its a process of elimination but dont know how to test the voltage getting through to the inverter or to test the backlight?
Many thanks, will give that a go now and let u know how i get on
Posted on Aug 07, 2008
  • 2,028 Answers
Only two things left. The screen itself or the connection on the motherboard. I believe the problem is going to be with a dead screen, so, replace the screen. If this doesn't do it, then I'm afraid the motherboard connection may have failed, and I'm sure you know what that means.
  • Ryan Rogers
    Ryan Rogers Aug 07, 2008
    On the inverter, you should be able to test it with an ohm meter. The inverter boosts the power from the board, back up to the level required by the screen, I couldn't tell you the exact voltage, only that on the screen side of the inverter the voltage will be comparable to the power of the wall outlet. The backlight can't really be tested, it either works or it doesn't when power is applied. Don't completely rule out the motherboard connection yet, I've had machines through my shop that seemingly had an inverter issue, that turned out to be that the pins in the motherboard connector that the inverter receives power through via the screen ribbon/cable, were damaged or corroded. Cleaning the corrosion from the pins fixed several, but the ones with damaged pins i had to get new motherboards for.
The picture and sound come on then a few seconds later the picture goes off to black screen and sound stays on can you help please
Is there is any light in the screen at the time picture gose. If not, then Backlight inverter is faulty. All lcd tv have backlight to light the pixels. If you watch the screen very near then you will be able to see image on the screen. First of all check is there is any budged capacitors in the power supply. If there then replace it will solve the problem. If no then check the inverter board. Do on thing check the fuse in the inverter board. If the fuse is faulty then replace it. If the fuse blews again then the inverter board is short you have to replace invereter baord. It is not possible to repair the backlight inverter. You have to replace the board with a new one.Have added the picture of inverter board and budge capacitor for your reference. If you need any more assistance feel free to contact me by Fixya.
ajin_g_97.jpg ok
Sep 19, 2011 | Televison & Video
My screen intermittently goes blank (without lighting). I can see that there is something displayed and a connection to an external monitor shows that everything is working fine. I've disassembled the...
I've seen this problem time and time again. Replacing the inverter fixed it every time. HOWEVER it could always be the CCFL backlight as well. Both fortunately are VERY inexpensive. Changing the inverter is easy but the CCFL will be a little harder. Take your time and remember how to put it all back together and you'll save that $100. I'm sure it's either of those two that's causing the backlight issues. NO NEED to change the entire LCD.
Aug 22, 2011 | Acer TRAVELMATE 8371-944G25 LAPTOP LCD...
20/02/11 Dear Sir/Madam. I got my Dell Inspiron B130 from a relative almost three years ago. Last week I turned on the laptop but noticed only a quick flash on the monitor then it was completely...
you can not buy a back light on its own you would have to buy a screen or an inverter its best to take it to a computer shop where they will test the screen and inverter and say what is faulty
Feb 20, 2011 | Computers & Internet
My flat screen Poloroid TV went black, it hissed and cloud of gas or smoke escaped from the back of the TV and now I have no picture just sound. Is it dead?
No troubleshooting needed for this issue. Check the tv's warranty then call the manufacturer to get this tv replaced or fix. If tv's out of warranty you still need to call the manufacturer to ask where is the closest Service center that can fix your tv.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Can't get anything on LTV 40w1 HDC- blue screen only-------------
Thanks for using FixYa. From what you have described it seems that you might have a backlight inverter board issue with this TV set. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Jun 19, 2010 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
We have Westinghouse LCD TV model number is LTV-32w1 and the problem is that screen is black though we hear the sound of the channels of our Direct TV service. Does it mean that it is broken or still may...
Ur tv have a dead electronic's board known as a LCD inverter backlight board.Replaced this LCD inverter backlight board,u will get the picture back.Tries, to buy a refurbish LCD inverter backlight board for the replacement.It a long in shape board.
Mar 09, 2010 | Televison & Video
D600 Latitude laptop - LCD showing ghost/dim images
Connect an external monitor to your laptop and power it up, if you seethe normal Windows images then the video card and laptop is OK and theproblem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dimimage and/or dark display on the laptop's LCD screen indicates a faultyLCD backlight and it could be the inverter that supplies high voltageto the CCFL lamp or it is the CCLF lamp is nearly burnt out or burntout, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Thank you Sir, Have a nice day.
Sep 19, 2009 | Dell Latitude D600 Notebook
Does acer warranty applies on acer v193w's backlight?
Warranty booklet says: 3 years - parts
3 years - labor
3 years - backlight
May 09, 2009 | Acer V193w LCD Monitor
Since you have replaced the inverter and the unit works with an external monitor, then probably problems would be with:
  • CCF lamps (backlight);
  • inverter triggers and/or B+ supply.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | IBM ThinkPad T23 2647 Notebook
Backlight Problem
You are lucky it works at all. The system board has been compromised.
Jul 30, 2008 | HP iPAQ hw6515 Pocket PC
Dell Inspiron 6400 Notebook Logo
278 people viewed this question
Alun Cox
