Question about Kitchen Ranges
Gas ingniter won't spark on our Kenmore gas stove top. It was working intermitant but now not at all
  • Anonymous Sep 07, 2008
    This is really stupid but my stove is a GE one yr old and the igniter doesn't light upm anymore.I am sure it is made in CHINA
  • 623 Answers
Igniters need replacment the only solution is to change it
Posted on Aug 07, 2008
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
Nov 12, 2010 - Uploaded by
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ... > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Can the cooktop surface of my Kenmore gas range model 790.72903011 be removed
Most stove tops are removable for that very purpose.... after you remove the burners and the grills above the burners.... look for an edge and inch or inch and a half below the top... get something strong like a large screwdriver and place cloth over the tip to prevent scratching the stove top. there are VERY STRONG CLIPS holding the stove top to the stove, pry upward until the clips release. then slowly remove the spark igniter (TAKE A PICTURE WITH YOUR CELL TO REMEMBER HOW PUT BACK TOGETHER)
Jul 30, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Gas range top igniton not clicking, gas come on when lit with a match
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
Sep 13, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Spark igniter discharging when turned off
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Jan 11, 2009 | GE 30 in. JGP328 Gas Cooktop
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Kitchen Ranges Logo
238 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
