Question about Microsoft Xbox 360 Console
Xbox 360 installation to the line 1 input of a vcr
When I installed the two audio in lines and the one video in line to my vcr, when I tried to play a dvd, the picture on my tv would fluctuate in brightness from dark to bright. If I plugged the video line directly into the video in plug on the tv, it worked fine. Why is that?
  • 37 Answers
Its possible that the video line going from vcr to tv has a short, if you have other rca cables try those. If not it's possible that your vcr has issues.
Posted on Aug 07, 2008
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
Rf but no video and sound
S-Video Hookups
Note: The S-Video cables are not compatible with the redesigned Super Nintendo. They are sold separately at most retail locations as well as nintendo's Online Store.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV or VCR.
Place the black end of the S-Video Cable into the S-Video IN on the back of the TV or VCR. Connect the red end of the cable to Audio IN Right.Connect the white end of the cable to the Audio IN Left. Use a slight twistingmotion when inserting the each cable and ensure the cables are firmly pressed into the input.
Connect the rectangular (gray) plug of the S-Video cable into the multi-out connector on the back of the Control Deck.
After system is connected to the TV or VCR:
Insert Game Pak fully into the Control Deck.
Plug the controller(s) into the front of the Control Deck using the left-most port for one-player games.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press Play, make sure the movie appears on your TV, then press Stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward the Game Pak).
Turn on the VCR and locate the input select. It's often called: input select, AUX auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You're ready to play! To record video games, set the system up to play games as usual, then insert a video tape and press Record. It's that easy!
Dec 27, 2011 | Nintendo Super NES Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
What's your problem?Im trying to hook up my xbox 360 to my JVC 27 inch TV, I installed the yellow to video input and the red and white to audio input and all get is the audio and no video. What am I...
Troubleshoot.
1. Ensure yellow is actually connected to an "input" slot.
2. Ensure TV is set to the correct input source.
3. Ensure your yellow, white and red RCA connectors are grouped in a single input source to TV. Sometimes the "component" and "composite" inputs are grouped closely together.
4. Consult the TV manual for hookup instructions.
5. Conduct a continuity test on the yellow xbox wire with a multi-meter.
Oct 04, 2011 | Sega The Club - Xbox360 for XBox 360
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Apr 02, 2009 | Microsoft Xbox 360 Console
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Video and Audio Inputs will not work
I think you need to replace your video drum. You can get replacements for your brand of Combo on the internet.
Mar 30, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
