Question about Garmin GPS
John Parr, WHITTINGHAM, Northumberland, UK, NE66 4UW 7 August 08 GPS Edge 205 Serial no 68028252 This particular Edge was a replacement for a faulty one earlier this year. Until 10 days ago, this was functioning well. On 27 July, the screen went blank after about 2 hours of use. I restarted it as usual, but it only ran for about 40 minutes. Since then, it only runs for shortening durations, being now down to 20 minutes. The battery is fully charged each time before use. The clock, altimeter and distance recording all remain correct. Can you please assist. I have previously requested as to what is the running time when fully charged. The Manual suggests 12 hours, but I never get more than 6 hours. This is a repeat of my message sent on 2 August. Thank you John Parr
    New Friend:
  • 22 Answers
I have an Edge 800, the battery usually lasts for about 4-5 hours, good for most cycle rides for most riders.
Posted on Apr 07, 2017
SOURCE:
SOURCE: Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Posted on Nov 08, 2007
  • 4 Answers
SOURCE: Blank Screen
hello, replays those 2 smd ic's and the tomtom will work again!!
best regards
alex from holland
Posted on Jan 20, 2008
New software is out 2.50 will fix problem with waas.
Posted on May 27, 2008
SOURCE: GPS screen went blank
My problem exactly. Unit would start up, acquire satellites, then the screen would go blank with a single vertical line. Unit would not respond to buttons or even turn off. Unit works fine after I did the reset:
- w/unit OFF, press and hold QUIT+DOWN+MENU
- press and release the power button, release DOWN, keep holding QUIT+MENU for 5 seconds.
- unit prompts something like: "erase all data;" choose yes.
- you will lose waypoints, etc.
Go to the Garmin support area for details.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Search for: "How do I reset my gpsmap 76"
Posted on Oct 06, 2008
johnegan84
  • 74 Answers
SOURCE: Edge 205 turning off through runs
There is a generic battery contact problem in the body of the gps, same in 305...this link will show you how to remedy it..MTBGurublog i have done it with my 305 and now do not have the shutdown anymore.... But, before you perform surgery try a full reboot... turn unit off then press mode and power together... unit will ask if you want to delete data..select yes and then manually insert all data again
Posted on Mar 27, 2010
I have twice had my order cancelled as you say you cannot deliver outside of mainland UK!!! I have asked for delivery to MORPETH, which is in Northumberland, ENGLAND so do not understand?? This has...
it is possible that you are on the wrong site as this is fixya site and has nothing to do with amazon
cause you cannot read what site you are complaining on, it is also very possible that you are not putting in the corrrect UK code for your area
best advice --contact your UK amazon office and correct the problem with them
May 12, 2017 | Cameras
Tip
How to reset your Garmin Edge 205 or 305
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
on Sep 05, 2010 | GPS
Need serial number for garmin nuvi 205 so i can get map updates
Doesn't matter what the serial number is, you have to pay for updates unless you bought the lifetime map update package. Try going to Garmin.com
Jan 26, 2011 | Garmin nuvi 205 GPS Receiver
System software missing
If you see this error message the device will need to be sent to your local Garmin office to be replaced. To obtain the contact details of your local Garmin office click on this link http://www.garmin.com/uk/support/contact-support
When contacting Garmin product support be sure to provide the following information as this will speed up the process of the unit being booked in.
  • Full Name:
  • Contact Telephone Number:
  • Address:
  • Postcode:
  • The serial number of the unit
Nov 12, 2010 | Garmin nuvi 205 GPS Receiver
Garmin edge 705 will not turn on
Nov 08, 2010 | Garmin Edge 705 Handheld GPS Receiver
My garmin edge 205 stops aften one houre of biking whay?????
I guess battery is charged ? please check battery level when starting the ride.
If it is an old device the battery maybe outdated (end of life). It may be changed.
Apr 28, 2010 | Garmin Edge 205 GPS Receiver
Garmin edge 205 will not acquire satelites
Check that the option disabling GPS receiver is turned off ...
Oct 13, 2009 | Garmin Edge 305 GPS Receiver
Aug 06, 2009 | Garmin Edge 305 GPS Receiver
I formatted garmin nuvi 205
You have not only erased all of your maps but you have also erased all of the internal software that was a part of your Garmin. I do not recall seeing anything on the web site that resolves your issue. If you can get a hold of another 205 perhaps you can make an image file of its software and then transfer that over to yours.
Apr 22, 2017 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 205 voice stopped working
I had the same problem. I went onto Garmin.com and attached the Nuvi to the computer using a cord that I had for my blackberry phone. Once connected, I turned on the Nuvi and ran the update tool. The update tool will reinstall the voices. This seemed to work the first time. I have had to do this twice now since I received the Nuvi 205 on December 26, 2008 (it's February 13, 2009)
Aug 09, 2008 | Garmin Edge 205 GPS Receiver
GPS Logo
61 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
