Question about HP Color LaserJet 2600n Printer
Strange printing issue.., need assistance ASAP!!
Currently working in Iraq and one of my clients HP 2600n will not print. The printer was connect by way of server and this problem happen once before, so it was reconnected by way of IP. Everyone else can print to this printer w/no problem. Once you send a test page to it, it's indicated on the printer by the green light and msg: Document printing...... However, it never cycles through the print process and gives no reaction at all. I've had the client reboot both the printer and the computer. I ping the IP of the printer w/the computer and got a 100%.
Please advise at this point. Not sure if there's a setting on the printer or what.
Thanks in advance,
Clueless!!
jrd
  • Irbil Tech Aug 07, 2008
    Thks "checkitright" for your assistance. After further troubleshooting, it appears the cat-5 connection was faulty. After reconnecting it, I did a test print page and whaaa laaaa, it produce the info on paper. Once again, thk you for your speedy reply and attention to this.
    Irbil Tech
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
When it receives the test page and doesn't react
1-does it go back to ready?
2-do you have to physically hit ther green button?
If everyone else can print ok then it can't be the printer !!!!
and you can ping it with no problem,
1-are you sure it is set correctly go to the properties setting under device settings is everything ok.
2-I suspect his driver is bad, try to reinstall.\
3-you can try to do a cold reset, although I don't think it will do anything since it's mainly one user problem.
Posted on Aug 07, 2008
Sir thanks for your hp 2600n printer suggestion but still problem is not solved blur image and prints double image
You can read about how to solve print quality problems for this printer on this page.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826#A6
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 12, 2011 | HP Color LaserJet 2600n Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
I have two HP 2600N printers that print Yellow onto the whole page. Replaced Toner and it wont and worked for a short time and then got worse with the yellow on the page. One of the units says yellow toner...
Generally this is a toner cartridge issue. Are you using genuine toner cartridges or generic remanufactured? I have attended alot of repairs on this model when clients use generic cartridges. Usually a genuine cartridge fixes the problem.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Apr 23, 2009 | HP Color LaserJet 2600n Printer
Strange Printer Problem - HP LaserJet 2600n
Sounds like a permission's issue,
Check her/his permissions on the printer's list.
Hope this helps
Regards
Richard.
Apr 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
Can't print after complete installation
Try printing a test page from the printer itself. This will determine if it's a communication issue or the printer itself
Jul 26, 2008 | HP Color LaserJet 2600n Printer
Not able to print
Check for the connectivity if you have connected to network, Check for any client is using the printer spool , check this if not put me ......................|
thank you
Feb 22, 2008 | HP Color LaserJet 2600n Printer
Cant print in my network
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Feb 15, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
42 people viewed this question
Ben Johnson
