Question about Panasonic DVD-S35 DVD Player
Dvd player problem
H2O appears and doers not play disk please helpe with a solution
Panasonic dvd s35 it doenst plays always display the H2O
Posted on Nov 09, 2008
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
I have philipd\s dvd player model no. DVP3126K/56.
Check with other DVD disks, see if it play,might have bad disk in that one,like scratches,cracks,or smushes.The disk u playing is a chamerical DVD Disk right?Not burn disk?Might just go in Ur DVD player just reset every setting back to the factory setting.
Oct 31, 2009 | Televison & Video
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Dvd player wont read displays H2O panasonic 2001 model
try cleaning the scanner eye with the cleaner disk
Jun 16, 2009 | Panasonic DVD-RV31 DVD Player
When i put a disk in the screeen appears with 'line in' and doesn't play
Perhaps, it's been accidentally moved the switch on LINE SELECT to IN position (the switch is located on the right side, near the back corner of the DVD player). The switch SHOULD be moved to OUT position.
Tah dah! It's playing!
Hope this is the case. Good Luck!
Aug 03, 2008 | Sony DVP-FX810 Portable DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
Nov 03, 2007 | Televison & Video
HDD to DVD
make sure you set dubbing speed to sp ,short play,thats the default setting,then go to start up menu and finalize disk
Oct 11, 2007 | LG RH177 DVD Recorder/HDD Recorder
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Panasonic DVD-S35 DVD Player Logo
167 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
