Question about Motorola Mobility RAZR V3i Cellular Phone
Motorola v3i why is my v3i's lifespan is only 7 hours, even if i charge it for many hours.. i tried to buy a new battery but theres no difference
  • bantrybhoy Mar 05, 2009
    I fully charged the battery in the morning and needed to charge again the next morning. Is that normal?
  • Anonymous Mar 05, 2009
    my v3i's battery doesn't last a long backup
    Brigadier General:
  • 7,752 Answers
Most lifetime of motorola batteries
Posted on Aug 08, 2008
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
I have one motorola RAZR V3I; WHICH IS NOT CHARGING EVEN A NEW BATTERY. KINDLY LET ME KNOW THE ADDRESS OF THE SERVICE CENTER. I AM STAYING IN CIVIL LINES, DELHI
the reason your phone is not charging a battery is either because the charger or the charging port or the battery terminal is faulty.
To test if it is the charger try it on another motorola phone, to see if it works, ifit does not, then you can replace the charger.
To test if it is the battery, try the battery in another similar phone and try to charge it to see if it works, if it does not then it is the battery that needs replacement.
To test the terminal head, get a meter reader, open the phone and test the battery terminal if it does not read it, then it is the terminal that needs replacement.
To test if it is the charging port, try a new tested ok charger on it to see if it work, if it does not then the charging port has a fault and needs replacement.
If you still insist on cantacting motorola, their contacts are below.
No information on any motorola close to Delhi.
GLOBAL HEADQUARTERS Motorola, Inc.
1303 East Algonquin Road
Schaumburg, Illinois 60196 USA
Telephone: +1 847 576 5000
Primary office locations: www.motorola.com/global
General comments or questions: Have a question or comment about a Motorola product or service? Contact us:
Tel.: +1 866 BUY MOTO (U.S. only);
+1 888 390 6456 (TDD/TTY).
Email: mot_mailbox@custhelp.com
Jun 15, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Battery
If you tried to make a charger you could have damaged the Pinout or even the charging port on the phone however 99% of the time this common error with razrs is fixed by trying a different battery and or a different charger.
Jan 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Drains battery in 24 hours
THE BATTERS ARE DESIGNED TO WORK ON STAND BY FOR ABOUT 3 DAYS BUT THE MORE YOU USE IT THE FASTER IT DRAINS TALK TIME ABOUT 18 HOURES CHARGE EVEY NITE SHOULD SOLVE THE PROBLEM
Sep 18, 2008 | Motorola Mobility RAZR V3
V3i
hi..ur motorola v3i is defaulted with 7 to 10 hrs of battery life only...o save more power...
  • Keep the brightness on the screen to a minimum. You can also adjust how long the backlight stays on without input from the user.
  • Turn off the Bluetooth when not in use. Bluetooth is a big battery draw.
  • Disable incoming beams so that the phone isn't constantly "searching" for infrared partners.
  • Completely close non-essential programs. When you run an application, it does not shut down completely when you "close" it. It is simply minimized. Go into the Settings to completely shut down any programs you are no longer using
  • also u cud get a car charger so that u cud be sure not to run out of juice..
    Thanks for using Fixya
    Aug 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Not charging
    when battery cannot charge, try another battery. If it is still cannot, then the problem is the charging port is not working. Need to replace it.
    Mar 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Battery doesn't charge
    change battery first and if it stay not charging download the new software
    Feb 27, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Battery
    well...sir they do die quickly no matter the age of the battery......but you should buy a new one
    Jan 26, 2008 | Motorola Mobility RAZR V3
    Motorola Mobility RAZR V3i Cellular Phone Logo
    50 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    Lawrence Oravetz
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
