Question about Fargo Pro L ID Thermal Printer
Problem while printing black on the black side
Hi, I have a problem using Fargo Pro-l with Windows XP. When the back side is printing with a YMCKK ribbon it stops and send a message: "printing back side" thus it doesn't work anymore. If I change the ribbon for a YMCKO type it works fine, bu it spends a lot of ribbon.
  • 526 Answers
Check the printer driver and see if YMCKK is selected in the driver.
Posted on Apr 23, 2009
Why my Fargo ProL Printer is not printing my Card Back Clear?
Hi, Its not clear what you are saying.
First, what kind of ribbon are you using for printing, and what kind of lamination ribbon are you using?
what are you trying to print on the front and back?
Feb 17, 2015 | Fargo Pro L ID Thermal Printer
Windows 7 fargo printer drivers
There are no Windows 7 printer drivers available for the Pro-L printer. You may try using the original Windows XP driver if you know how to setup a virtual XP environment in Windows 7 Pro. This requires you to install the printer and the software that uses it inside the virtual XP.
Dec 04, 2013 | Office Equipment & Supplies
When I try to print it appears an error: flipper jam
Try to disable double sided printing in the Fargo settings?
That should make the Filpper shut down,
Selvol
Mar 06, 2012 | Fargo Pro L ID Thermal Printer
My fargo printer prints black and white on the back of the card
Possible solution: Change the resin dither from Optimized for Graphics to Optimized for Photos with in the printer driver under the image color tab.
Feb 23, 2012 | Fargo DTC525 ID Card Printer
I have an e machines computer with windows 7 home premium. It has an AMD Athlon II x2 235 e processor w/2.70 GHz. It has 6.0 GB RAM w/5.75 useable. And a 64-bit operating system. Is my computer powerful...
As this is an older printer, the requirements are very low, a Pentium class 166mhz computer with 32mb of RAM is the minimum requirement.
By manufacturers documentation, this printer is not supported by Windows 7. Its best if used with a Windows XP platform.
-- The Pros at DiscountIDStore.com
Dec 28, 2011 | Fargo Pro L ID Thermal Printer
I need to install a fargo pro L on to a computer with xp professional.. and its not working. can somebody help me.
Click on the link below to download the drivers for Frago Pro L on XP.
Download the software and run the file to start installation.
Frago Pro L Driver
Check page 22 of the Pro User's Guide, you can download from FARGO support pages. Here are the links to the available manuals for your printer:
The process of downloading the manual may take some time.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | Fargo Pro L ID Thermal Printer
I have bought a Fargo Pro LD Thermal printer, and have a windows xp desktop and a windows vista laptop. My problem is the driver that came with the printer is for windows 98. How do i go with instaliing...
The support options seem to be limited. However, I found an Win2K and XP driver here: http://drivers.softpedia.com/get/PRINTER/OTHERS/Fargo-Pro-L-Printer-Driver-202.shtml . Click on the Download button on the left and then click on the download from External Mirror link.
For Vista, you may find the Compatibility option works. Right click on the file you downloaded (after unzipping if it ends in .zip, find an .exe file in this case) and choose Properties. Then click on the Compatibility tab. Set that up to run the program as XP. Then right click on the file again and choose Run as Administrator.
I hope this helps.
(my anti-virus software hasn't flagged this site or file as a problem; however you may want to check further for malware.)
Nov 14, 2010 | Fargo Pro L ID Thermal Printer
I need fargo pro L printer driver for windows 7
According to the Fargo Website:
http://fargosupport.com/archive_results.asp?archPrinter=5&archSubmit.x=42&archSubmit.y=5
The drivers only go as high as windows xp for now. Hopefully since Windows 7 is coming out soon that they will have a driver available for it shortly.
Aug 15, 2009 | Fargo Pro L ID Thermal Printer
Fargo pro-l using too much ribbon
It sounds like you may need to calibrate the ribbon sensor.
Go to the driver icon in your printers folder.
Right click on the Pro-L driver's icon, and select "Printing Preferences".
Click on the "Advanced" button in the lower right corner. A new window will open.
Scroll to the bottom and you will see "Calibrate...". Click on that and a button appears next to it that says "Properties...". Click the "Properites" button and another window appears.
On this screen, you'll see a button on the right side that says "Sensors...". Click on it, and yet another window opens. Almost there.
Here, you'll see two sections. The top section is for calibrating the ribbon sensor, the bottom is for the lamination sensor. Remove the ribbon and close the lid. Click on the "Send" button in the top section to calibrate the ribbon sensor. Your printer should beep twice.
After that, hit cancel on the previous windows to close out everything.
Normally this fixes this kind of problem, but if it doesn't, then there is something broke in the printer, possibly the sensor itself.
Dec 13, 2007 | Fargo Pro L ID Thermal Printer
Fargo Pro L ID Thermal Printer Logo
129 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
