Question about ASUS VIA KT133 Chipset A7V133 Motherboard
ASUS VIA KT133 Chipset A7V133-M IDE drivers
Installed XP, and now it cannot find IDE
  • Anonymous Sep 10, 2008
    system hangs up during operation
  • 84 Answers
Must install motherboard drivers right after you install XP ( chipset is always needed first ) If you use Nvidia drivers or a 4 in 1 make sure you do those first before anything else .
Posted on Aug 07, 2008
Sata drivers pt80c-alx boot
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2013 | Computers & Internet
WHY WINDOW DOES NOT INSTALL
If you are trying to install Windows XP on a SATA hard drive then.
Jan 12, 2013 | Toshiba Satellite Computers & Internet
My laptop it dosent asept windows xp
Dec 26, 2012 | Toshiba Satellite L45-S7409 Notebook PC
How do I install sata drivers
Oct 12, 2012 | Toshiba satellite c660
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
Windows xp not installing
If your hard drive is a SATA drive then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Jun 02, 2012 | Computers & Internet
Show blue screen and show error 0x0000007b during installation windows xp
I assume your trying to install windows xp on a somewhat newer computer. This will not work without some tweaking. The reason you are getting this error is due to the fact your computer most likely has a SATA drive as opposed to an IDE. Windows XP does not natively support SATA drives.
First thing you can try is go into your BIOS and change your hard drive to emulate IDE support (To get to BIOS, while the computer is booting you will need to press the key is asks for to enter setup/BIOS usually F1 F2 F10 or del)
Here's a video I found on youtube that explains it, you want yours set to IDE. After this is set, XP should install just fine.http://www.youtube.com/watch?v=PVXXopxa7hg
The other option is to build a slipstream XP disc and integrate sata drivers into it so that you can install XP on a computer with sata. This is much more advanced and I would try to emulate IDE mode first.
Leave comments if you need additional assistance.
Aug 04, 2011 | Computers & Internet
How to install XP in Acer Extensa 5630Z
just goto the BIOS and make hard Disk detect as IDE simply by changing the Detect Harddisk as value SATA to IDE then u can install XP
Jun 04, 2009 | Acer Aspire 5610-4648 Notebook
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
ACER Aspire M5620 System Serial Number: PTS860X0227410A4022700 I want to put windows XP on it but it has window Vista. So to put Xp on the computer i went into the bios and try to change the setting...
You cannot just switch from RAID to IDE!!!
This has nothing to do with the operating system!
It is a hard disk control and arrangement protocol for transmitting and storing data.
RAID: Redundant Array of Independent Disks
IDE: Integrated Drive Electronics
It is a hard disk drive interface and RAID is commonly used in servers for data redundancy and faster access. There are several versions of RAID. RAID Wikipedia
if you want to install Windows XP first of all set in the BIOS back to IDE (or simply choose default settings)
Start up your computer save any data you might want to save.
Reformat your hard disk (you will lose anything you had not backed up) and install XP presumably from a CD you have.
ultimately you can install XP and just tell her during install to reformat the hard disk.
Nov 07, 2017 | Acer Computers & Internet
ASUS VIA KT133 Chipset A7V133 Motherboard Logo
575 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
