Question about Hotpoint WMA50 Front Load Washer
SOAP DISPENSING SOMEONE TOLD ME THAT LIQUID SOAP SHOULD NOT BE PUT IN SOAP DISPENSER AS IT DOESNT GO WELL DOWN AND BRINGS THE MOLDY SURFACE UNDER THE SOAP DISPENSER, THEN HOW DO I PUT THE LIQUID DETERGENT IN MY WASHING MACHINE.
  • Anonymous Mar 13, 2014
    soap dispenser going black
  • Anonymous Mar 18, 2014
    Soap door doesn't open and when soap is put in the bottom of the dishwasher, still won't wash
  • 481 Answers
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Posted on Aug 08, 2008
How does soap dispenser work? what does up for liquid and down for powder mean?
Liquid laundry soap (comes in plastic liquid container) uses the up. Dry powder laundry soap uses the soap that comes in a box, therefore not liquid. and uses the down switch slider control.
Apr 14, 2015 | Maytag NFW7200TW Front Load Washer
Leaking a small amount of thick liquid out the bottom
Take off the outer door cover sounds like the dispenser leaking
Jan 28, 2015 | Dishwashers
How do i clean the mold in my soap dispensing on a HE5t steam washer
Open the drawer and there is a tab at the rear, press down on it and the drawer will come completely out where you can take it to a sink and clean it good with some Tilex and a toothbrush. To reinstall it just push it straight in.
Aug 03, 2014 | Kenmore Washing Machines
Frigidaire affinity soap dispenser doesnt work
Good Morning Friend, this is Z. I appreciate your post!
I see that you have a Frigidaire washer and that you are having trouble with the soap dispenser. Is the soap dispenser not dispensing bleach or softener? Is there water left in the dispenser? Are you able to open and/or close the dispenser? Also, may I have your model number please? You can normally locate the serial on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you!
Jul 26, 2014 | Frigidaire Washing Machines
The smart soap dispenser on my GE profile dishwasher is not dispensing soap. I filled the smart dispenser several months ago and it does not appear that any of the soap was dispensed. how do i resolve?...
We mistakenly switched liquid detergents and mixed enzyme based and bleach based. They gelled in the dispenser. I took the outer door cover off and could not figure out how to take the white plastic despenser off of the main door without breaking it. I disconected the electrical harness and took the main door off the hinges so I could take it outside, turn it upside down and use the garden hose pressure nozzle to blast the gellout of the white plastic dispenser. I use a piece of plastic coat hanger to poke around inside to break up the gell several times. It all came out in marble size pieces.
Aug 17, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
How do you put the liquid soap dispenser back
The "bottle" screws in from the bottom. The "pump" is inserted in the top. I usually fill mine from the top without taking out the bottle. Too much of a pain. Just make sure the large nut holding the hardware in place is secure before you start assembling the bottom and top. If it's loose, the whole thing will wiggle around. Good luck!
May 07, 2010 | American Standard Contemporary Kitchen...
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Soap not fully dispensing
Good you have he soap, powder is not a good option and maybe there is too much. Liquid soap should be no more than 2 Tbls and softner 1 Tbls. These machines use 50 gallons less water than a top loader. If you soap is ok than you can inspect the dispenser. The top cover has three hex screws on the back, ones with a torx use a 9/32 and if not a 1/4 socket. after you pull this cover off, push back and then lift noting a catch is on the front behind the console for alignment at replacement, you will see a white box with a spring loaded cam attached to a arm with a motor under it. Check for lime deposits careful to not loose the spring. Start a cycle and observe for hang ups sometimes a drop of 3 in 1 oil at the dispenser side does wonders.
Sep 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana Front Load Washer Soap Dispenser
I suggest you use soap powder for 'front loading washing machines'. The cartons at the market have them specially marked.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
409 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
