Question about LG LSC121PMA Split System Air Conditioner
No heat i have a split system and until yesterday the heater was working - now it pumps out only cold air when i need it to heat the house. the subfunctions defrost and utdoor have mysteriously come on. what can i do? any help would be greatly appreciated
  • Allen Neal
    Allen Neal May 11, 2010
    need to know type of unit and did anyone change any parts lately . as well as the type of emergency heat it has for back-up or is it a simply heat pump only( ie) gas , electric , lp gas oil ect
  • 400 Answers
Please make sure that the correct mode setting has been selected. Depending on model you will see the mode button has four little icons. A star/crystal, a teardrop, a sun (circle with lines out going) and a sort of triangle. You press this button until the correct icon appears on the display, it should be the sun icon.
Posted on Mar 05, 2009
Carrier fa4anf036 home heater not a car. Blows luke warm common for an electric heater?
As near as I can tell from internet information. This model is a heat pump. It transfers cold air out of the house and gets what ever warm air might be outside the house. In extreme cold weather an auxiliary electric heater should make up the difference. The filters must be clear. There is a limit what the heat pump can do in cold weather. Your electric heater may not be activating. You could try raising the thermostat. A service technician may be needed to determine why the electric heater is not working.
Jan 01, 2018 | Heating & Cooling
Have oil heater that we had serviced yesterday. Heater stays at temperature but circulating pump will not send heat to upstairs radiators. (heater in basement) Any advice?
Try putting in central heat and air in your house don't rely on some basement heater then you will have a basement heater for when it get cold
Dec 03, 2013 | Lakewood Oil-Filled Electric Radiator...
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
Apr 15, 2010 | Cfm Daikin R410a Split System Air...
Air from the heater is not really warm.
Have you changed your air filter lately?
Dec 03, 2009 | Heating & Cooling
Is the pump flow to or away from the watermaker?
In city water or well water system ... the cold water flows from the tank (or meter) toward the hot water heater. The cold water splits in two (so to speak) at the heater with one part going on to the house to supply all cold water needs while the other part goes into the water heater to be heated. On the other side of the hot water heater, there is a system that paralles the cold water system to supply the hot water needs of your home.
I hope this answers your question.
Oct 16, 2009 | Water Heaters
How to make the heater work on the air con in the house split system no user guide its cold
set the thermostat on a higher setting turn it to heat position if that don't work thermostat may be bad. Good luck Tom
Jun 27, 2009 | Heating & Cooling
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
Heating problem with one split in a double split system
Either the board or capacitor have failed. If the motor is HOT the motor could also be the problem. in oder to tell if it is the board you will have to check to see if there is power coming fromthe board at the place where wires hook up. If power is there then it is either the motor or cap.
Feb 02, 2009 | Heating & Cooling
Ford taurus Wagon 2001 heater problem
Check your coolant level. If the antifreeze is low the water pump may not be able to pump enough of the coolant through your heater core. When the car runs faster it is able to pump more of the warm antifreeze to the heater core.
Dec 02, 2008 | 2001 Ford Taurus
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
180 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
