Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
Jan 16, 2015 - The devices can have some control over the TV, and the TV can have some control over ... AOC: E-link; Hitachi: HDMI-CEC (Thank you, Hitachi!) ...
May 18, 2012 - Hitachi - HDMI-CEC ... You can control your computer with your TV'sremote control and you can set up that your laptop shuts down or goes to ...
I know it Sounds silly I also have a Hitachi TV and got issues with HDMI, I unplugged from wall for 15mins and turn it back, then I tried my PS3 and worked.
If not there is a firmware update on the website however it needs to be uploaded by a "technician" via USB drive mine has a USB port but there is no update for mine.
You will need to replace the lamp. That is the only thing that will cause the picture on a DLP to go dark. Please take a few moments to rate my answer. Thanks....
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear. When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
