Question about Yamaha Dtxpress Iv Special Electronic Drum Set
Electronic drum kit, with USB out, problem
I have an electronic drum kit that I want to use to record with. This particular kit has usb out. I plug the kit, via usb, it into the comp and it recognizes the kit as a usb MIDI device. This is also listed as a usb MIDI device Home Studio. I open a new blank project. I import a wav file using File>Import>Audio (to record the drum track for). I then add a MIDI track. Under "Options...MIDI Devices" I select the kit as a MIDI input device. In the MIDI track, for the input, I select "usb MIDI device", and output to my built in sound card.
I have tow problems:
1. When I hit the pads on the kit I hear some of the pads, but the voices are all messed up.
2. The lag time is so long that even if the voices were right I couldn't record anything anyway.
What can I do to fix this mess?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 10 Answers
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Posted on Aug 07, 2008
SOURCE:
Problem with dm6 and hiss problem
The amplifier may be turned up too high!
Jan 12, 2013 | Alesis DM6 USB EXpress Kit Compact...
The snare triggers incorrectly
hello....just had the same proble... u probably need to clean or fix the port... (if u try to pull out just a little bit the jack u can see that everything it works properly).
I opened the snare (ccrew it out) , i cleaned the components with some spray and noweverything works.
let me know
ciao
Sep 24, 2012 | Alesis DM7 USB Electronic Drum Kit
Alesis DM7 bass drum wont work
the solder on my kik keeps breaking off. you might have sensitivity issues. it can be adjusted on module.
Jan 22, 2012 | Alesis DM7 USB Electronic Drum Kit
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
Mar 27, 2011 | Simmons SD9K Electronic Drum Set
How do i record drums from drum kit
Hello nastyneph320:
Computer connectivity (via USB, Ethernet or the FW16E FireWire option) and DAW integration features like 8 zone Master mode, DAW remote control and cross platform editors let you seamlessly integrate the Motif with any DAW software, including the bundled Cubase AI software.
Translated it means that you can use USB, Ethernet, or FireWire connection to your PC and use DAW or Cubase AI software for recording. But I'm pretty sure you could use some other type of software for recording as long as it accepts your Keyboard.
Don't forget to vote with a thumbs up if this helped.
Feb 26, 2011 | Yamaha MOTIF XF8 88 Note Workstation...
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
593 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
