Question about Evga nForce 680i SLI (122CKNF68) Motherboard
Motherboard message LED message is --
I just got back after a month abroad and when i turned on my computer it doesnt turn on. The motherboard LEDs show -- which isnt in the user's manual. When turned on all the fans for the CPU,Ram n chassis are working but the computer doesn't turn on. Also when turned on, the computer doesnt make the "beep" sound that means it is on. Can anyone please help me?
  • Anonymous Nov 15, 2008
    i have the same problem, except for i cant take it out of the case and hook it up and it runs.i made posterboard gasket so that the bottom of the motherboard wouldnt directly touch the case,still nothing.i made little posterboard washers for both sides of the motherboard....still nothing. if anyone has any ideas, it would be greatly appretiated
  • 84 Answers
Your motherboard has died .
No beep code explains it all .
LED lights and even fans spins only tells me that your getting power to the motherboard , but No beep code is crucial .
Every motherboard will beep once when your first turn on and beep once again before the Opertional System boots up .
Sorry again for your loss ...
Posted on Aug 07, 2008
SOURCE:
Booting problem
You may want to check your harddrive if you cannot boot to windows but the machine turn on (leds light up) you may need to replace you Harddisc.
If the machine does not turn on at all (no leds, no fans spinning) you may want to check your power supply. if that doesnt solve it check you memory and mainboard.
Feb 25, 2011 | MSI 6714 i845GL Chipset 400/533FSB...
New case and new motherboard, when trying to turn on computer, power button doesnt work
Carefully double check the connection header pins and the leads that come from the front panel for LEDS indicators and push button switches. The motherboard manual will indicate what the numbering scheme is for the header pins (which pin is #1, etc.) and where they are physically located on the board itself. You may have simply connected one or more switches and indicators to the wrong pin. Getting them straight should solve the problem.
Mar 19, 2010 | ASUS M2N68-AM SE2 Motherboard
Dell D600 when powering, leds blinking
Its a motherboard problem. check all the flashing codes here.
CLICK HERE
it will give you all the information about the codes.
Sep 26, 2009 | Dell Latitude D600 Notebook
I have a ASUS Asus P5E3 Deluxe Motherboard. i installed and used for about a month and it took a **** on me. i turn it on and the MoBo turns on, but doesnt give me anything on the screen. MoBo isnt in...
i have same problem i have a ASUS P5E3 Deluxe Motherboard but everything was new but when i on allthe light is runing good but no beeps on my bord or signal on my screan?
Sep 24, 2009 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
Won't boot
power supply isnt putting out enuf power
Apr 25, 2009 | Intel Motherboard
Dead sharp pc-ax40
You can try reseating the memory and the hard drive if you can get to it, but it sure sounds as though the motherboard is shot.
You can take it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | Sharp Computers & Internet
Asus p4vp-mx cpu fan turns nothing else works
Try to removed the memory and cleaned with pencil eraser the contacts and install it back.
Jul 13, 2008 | ASUS P4VP-MX Motherboard
Technika digital camera driver issue
This isnt a motherboard problem actually.
The user you are useing to run the setup doesnt have admin rights.
Try makeing a new user and make sure it is set to computer administrator. If you cant do that then your user doesnt have admin rights.
If you can do that then go to the new user and try to run the setup on it.
Its possible your pc has a virus or something has removed administrator rights from your user.
how to check does my user have admin rights?
press start -> run -> type: cmd -> type: whoami
it will show something similiar to this:
C:\Users\Käyttäjä>whoami
lh-g503w30x9mwi\käyttäjä
(''computer name'' \ ''user'')
now type: net user käyttäjä
(remember to change the 'käyttäjä' with your own username)
C:\Users\Käyttäjä>net user käyttäjä
User name Käyttäjä
Full Name
Comment
User's comment
Country code 000 (System Default)
Account active Yes
Account expires Never
Password last set 11.1.2008 11:30:25
Password expires Never
Password changeable 11.1.2008 11:30:25
Password required No
User may change password Yes
Workstations allowed All
Logon script
User profile
Home directory
Last logon 17.2.2008 13:01:20
Logon hours allowed All
Local Group Memberships *Administrators
Global Group memberships *None
The command completed successfully.
C:\Users\Käyttäjä>
Note I bolded the LOCAL GROUP MEMBERSHIPS. Seems I have administrator rights in my pc. how about yours?
Feb 17, 2008 | EliteGroup P4VMM2 Motherboard
Brother HL-2040 All LEDs stay lit and the printer no longer works
Turn it on and when all the LEDs light up, THEN press the Go button. One or more LEDs will stay lit and the others will be off. Look in the user manual (you can find it online at the Brothers site if you don't have one). There is a chart in the Troubleshooting section that will tell you what problem your particluar combination of "lit" buttons indicates. It may suggest fixes, or depending on the problem, tell you to see a repair person.
Nov 19, 2007 | Brother HL-2040 Laser Printer
Evga nForce 680i SLI (122CKNF68) Motherboard Logo
2,009 people viewed this question
Top Evga Computers & Internet Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
