Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
WANT TO SET UP SPEED DIAL ON MY FAX MACHINE
CAN YOU HELP ME ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Try this site they may have your manual
retrevo.com
Posted on Aug 07, 2008
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 10, 2010 | Brother IntelliFax-4100e Fax
Is there a way to program it to fax to a group of numbers at one time
You can use the "Broadcast " feature to send one fax to up to 112 numbers listed in your speed dial. To set this up:
  1. Insert the original into the ADF.
  2. Press Quick Scan/Reports. The display should show how much memory is available.
  3. Enter the One-Touch or Speed Dial numbers for the recipients you want to send to (one after the other). You can also setup a group dial number.
  4. Press Fax Start. The machine will scan the document into memory and then dial all the numbers you've entered. If any are busy it will attempt to redial.
  5. Press Stop/Exit at any time to cancel the broadcast.
If you need further instruction on how to setup group or speed dial numbers, Brother provides the user manual online.
Hope this helps!
May 15, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Apr 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
One Touch Dialing numbers won't permanently save to FAX machine
If you followed the procedure F 7, 2 set, 1 for speed dial, enter your free speed dial space, enter your fax #, set, enter the name, set.(continue to next free speed dial key or stop) If this doesn't work then you may have a bad battery on the main board that saves the data if the power goes off.
Feb 04, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
KEY PAD ON FAX MACHINE WON'T WORK
Have you programmed the  'rapid' (one touch) buttons or the speed dial numbers? (print a report of stored numbers to be sure)
Is machine set to fax mode?
Oct 15, 2007 | Brother IntelliFAX 4100 Laser Fax
How do I set up speed dial
Lift up the cover over the key pad and the is a key marked data registration. push it then push the set key. using the arrow keys scroll down to set up machine then push set, and find the speed dial feature again push set enter your number push set and go on to the next one. Good luck it is kind of confusing
Jun 14, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Speed dials
I'm not sure if this will help because I haven't seen a 2060 control panel but most Canon fax machines use the same process. Press either "menu" or "data registration" button. (Again -I'm not sure of 2060 control panel.) Display should read "user settings" Press the "down arrow" (looks like an upside down triangle) until the display reads "tel settings" Press "set" Display reads Speed Dials Press "set" Display should give the # of the speed dial (ie. Speed Dial 01) Press "set" Display reads "tel number" Press "set" input # you want to send faxes to Press "set" Display reads "Name" Press "set" use letters on keypad to input receivers name (ie. For letter "C" press #2 three times, you may have to use the arrow keys to move the cursor for names such as BC Corp) Once name is input - you guessed it- Press "set" you will now be presented with various other send options which most people/businesses never use. You can hit stop to return to normal mode. After inputting speed dial #'s & names,you can print a list of what you have input by getting back to the "Tel registration" screen & pressing the report button. I can be reached @ bspier@carlsonsupplies.com if you need more assistance. Good Luck!!
Jun 09, 2007 | Canon LaserClass 2060 Fax
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
24 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
