Cannot read print when I look up something. The size is fine to read on screen but prints unreadable
  • Amusiccook Aug 07, 2008
    the print is only the thickness of a SHEET OF PAPER
    Master:
  • 623 Answers
Check if you have ink it might be low
Posted on Aug 07, 2008
SOURCE:
Picture crop
HI,
One way is to go to your menu bar at the top of your web browser, click on "File" then "Print Preview". At the top of the window there should be a small window with "Shrink To Fit" in it. Click the arrow on that box for a drop down list and choose something, like 90% (there is a custom option at the bottom of the list if you need to set something unique in between what's listed) and see how it changes the print size of what is to be printed out and choose the one that looks and works best for you without cutting off text somewhere. This will make it larger when printed out.
Another way that usually works to make the print larger when printing internet stuff & emails is by changing the view size on the screen to a larger size in your web browser (this is separate from your other setting you've already setup). Go to the menu bar at the top (i.e. Internet Explorer), click on "View," then "Text Size" then select a size like "Larger" or "Largest" (something higher than what you're currently set to.)
Sometimes adjusting the current window's magnification (lower right corner of screen or Ctrl button + scroll wheel on mouse) can have an affect on print size.
The only other method is to copy & paste the text into a text editing software like Word and adjust the text size there. If you're using a text program, then you simply adjust the size of the text to a 12 or 14 point, or larger, font size (adjust depending on the font and size you need) and that should do the trick.
More info see this link.
https://www.inkling.com/read/photoshop-cs6-missing-manual-lesa-snider-1st/chapter-6/resizing-images
Thanks.
Technical Support
Feb 23, 2014 | Yahoo Computers & Internet
Can u adjust the size of the screen with the xbox controller
Is this original Xbox console?
if it is there is no way i am aware of
with 360 the text is small and unreadable because you are using an AV lead, you need to update to HDMI
Mar 05, 2013 | Microsoft Xbox Console
When print a file, the printer screen show ''Data Received'', So I can not print anything
the printer is missing something. Check if there is paper. also check to make sure you printed the right size paper. If you printed 8.5 x 11 sheet make sure that paper is in your tray or if you printed a different size make sure that paper is there. Than if all is good just restart your compouter and printer and it should be fine.
Jul 16, 2010 | HP LaserJet 5200 Printer
Printed font size too small
1. either the font size on you pc is small but as you see in zoom it appears big to you.
2. or there is problem with your print settings, try different setting and print, e.g. fit to page, must check print preview to get an idea of how much matter on how much paper.
Hope this helps
must rate me or ask if more questions.
Mar 23, 2009 | Computers & Internet
Printing from online comes out very light
Typically, the quality of images and text on websites is very low resolution to keep the file size down in order for them to load more quickly on your screen. Just because it looks good on your screen doesn't mean it will print the same. There are just fewer dots per inch in the text and images and they can appear faint and low quality when printed. Look for a print icon on some web pages as it will be at least formatted properly to fit the page and some are of better quality than printing what is on the screen.
When it comes to emails, if the text is in a color, especially blue, they will tend to print light. Change your printer settings to print grayscale and that should help sharpen things up about as much as is possible.
sharvey400
Dec 03, 2008 | HP Office Equipment & Supplies
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
LaserJet 6L Prints Outlook content too light
You can run into these problems when using non OEM toner cartridges. It sounds like anything that is printed in a light gray is not printing correctly.
Apr 28, 2008 | HP LaserJet 6L Printer
Size of print on printer
if you have a scroll mouse...hold ctrl and then scroll to adjust the size.
Feb 04, 2008 | Computers & Internet
I also had the google maps print issue on my HP3030 and fixed it by setting the "Default Quality" under "Copy Setup" from the HP3030 menu to "Photo" from "Test".
That's a hardware setting on the HP 3030:
Menu/Enter > Copy Setup > Default Quality > Photo
Hope this helps.
Terry
Sep 30, 2007 | HP LaserJet 6Lxi Printer
jasbo
jasbo
Ekse
Marvin
Marvin
