XEROX XC865 - No image
I have picked up a used Xerox XC865 recently.
It powers on, there are no warning messages, and the toner cartridge has been replaced, yet, no image is produced.
Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
You are not getting any transfer. There are two types of transfers:
1- Corona wire; a set of very thin wires (hair thin and usually gold) that sit exactly against the drum. they are eiher broken or the unit is shorting out
2- a black spongy roller, usually don't go bad may need some recalibration
other possibility is the Developper unit,
which may be going bad look at it does it have a coat of toner on it? if no and you can see the long roller (it should be a silver magnet roller) if you can see the silver then there is not enough toner on the roller, it should have a thin solid layer of toner all the way XEROX XC865 - No image - xerox%2520xc810%2520drum%2520cartridge.gif
Posted on Aug 07, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
09-800 Invalid Toner Cartridge Message
Verify that you are using oem Xerox toner cartridge. If you're using an Oem Xerox cartridge and still getting this error it could also be the Crum Board, part number 140N63302.
Apr 11, 2013 | Xerox Phaser 3635MFP/X Multifunction...
The secretary ordered 3rd party toner cartridges for a Xerox Phaser 6130. After replacing the black cartridge the "invalid cartridge" message comes up. Is there a way that we can use the 3rd...
If you get the "invalid cartridge" message, try completely turning off and unplugging the unit. Then remove the cartridge, close the door and after at least 30 seconds, restart the unit. Then reinstall the cartridge. This worked for me!
Sep 26, 2011 | Xerox Phaser 6130 Laser Printer
I have a Xerox 7300 that I started using Media Sciences toner in. I have had to replace 3 imaging units recently because they have locked up. Now 2 are locked up again. Media Sciences says they have not...
Hi.
Xerox says instead that the user should never used non original or refurbished cartridges, as in a number of cases this had been proven capable of damaging parts like the imaging unit.
I am sorry for Media Science, but they do not even have permission given by Xerox to build compatible cartridges (Xerox Corporation Filed a Patent Violation Lawsuit Against Media ).
Cartridges that have not built and tested with full printer manufacturer cooperation cannot be free of problems.
Also, I know that the 7300 is probably out of warranty, but using this cartridges on a new printer may invalidate the warranty.
Media Science does not make itself responsible in case one of their cartridge has damaged a printer.
My suggestion is to use original cartridges in future.
Best regards.
Ginko.
Feb 22, 2010 | Xerox Phaser 7300DN Laser Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Cyan is not working or printed over pages
Hi, Have you checked your cyan imaging unit?
R
Jun 18, 2008 | Xerox Phaser 7760/YDX Laser Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
jasbo
jasbo
