Question about Symbol MC9090 Barcode Scanner
I cant enable pccard-photon1
Am trying tp connect to wireless network and want to enable pccard-photon1
  • Anonymous Dec 10, 2008
    I have the same problem
2 Suggested Answers
SOURCE: Cant activate PCCARD-PHOTON1 in Symbol MC9090
First thing is to run the wireless utility.
Start >> Programs >> Fusion >> WCLAUNCH
Once thats running an icon will apear in the task bar.
Click the icon and select "Enable Radio"
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 15, 2009
Tp-link validating identity
To fix, you go into the properties page of your wireless connection, go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
  • by avatar11.jpg guitarage74 Over a year ago
    • By avatar12.jpgMac Campbell Jan 31, 2012
    • Thank you!!!! Worked on Acer Laptop like a charm. Mac
  1. This is a wonderful solution and I working at tp-link have found this has helped my customers over the phone countless times. Granted there are those "unique" situations. However, this is a great solution to help resolve the issue.
Jun 16, 2012 | TP-LINK Computers & Internet
Connecting TLWR743ND to BT hub
I spent ages trying to use tp- as an ap client. tried every setting I could think of. Then........ Changed wireless security setting on home hub 3 to use JUST WPA2 not WPA/WPA2 and all worked. Give it a go. :-)
May 04, 2012 | TP-LINK Router TLWR743ND 150Mbps Wireless...
I bought a TP-link TL-WN821N wireless network USB adapter. I installed the driver on my desktop and I cant connect to our network nor the internet. I connected it to my laptop and deactivated the...
Dear Joeri_troch This is Howard from TP-LINK Support Force. Could you please check if your desktop has recognized the wireless adapter? And can you see Wireless Network Connection icon?
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Sep 17, 2011 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
I installed TP-Link WN7200 on Windows 7 Home Premium, the drivers is not digitally signed. The adapter is disabled and I can't enable it. There is no error in device manager. Please help me.
It is ok if the driver is not digitally signed. There's no need to worry.
To enable the adapter:
  1. Click on the Windows Start button
  2. Type in "network"
  3. Open "Network and Sharing Center"
  4. On the left bar, click on "Change Adapter Settings"
  5. Select your wireless adapter
  6. Right click on the wireless adapter then select Enable.
If you cannot select Enable, it means your adapter is already enabled. The adapter has a gray icon due to it not being connected to a router.
May 09, 2011 | TP-LINK TPLink Tp link Tl wn7200nd 150mbps...
I am using tp link adapter wn650g. i have two problems 1) when i click the tp link icon on the task bar it says authenticating on the link status. 2) although i have a 108 mb card but it always connect...
Hi!
The Authenticating status means that you entered an icorrect network key. The 54Mbps is the wireless speed that your card is getting from the wireless router. That means that your router can only broadcast a maximum speed of 54Mbps. This is usual for Wireless-G routers. Although your card is capable of receiving 108 Mbps, the router doesn't have that speed. The 108 Mbps can be attained if you have a Wireless-N router. To resolve the Authenticating error, try to reconnect to your wireless network using the TP-Link utility. Make sure to enter the corrent wireless network key also called as passphrase. If you are using WEP as security mode, follow the steps below
For Win XP
1. Go to Control Panel, Network Connections
2. Right click on Wireless Network Connection > Properties
3. Click on the Wireless Network Tab and at the bottom you'll see Preferred Networks
4. Highlight the name of your network and click on Properties. Click on Authentication tab then uncheck the option that says "Enable IEEE" something like that. Click OK all the way out
5: Check if that fixes it. You may also try to reboot the computer after that.
One more thing is you can try to change the Channel of your router. You can do that by connecting your laptop hardwired to your router then access router web interface
Feb 18, 2011 | Computers & Internet
I have installed my new TP-link wn350GD and installed the driver included but stilll i cant connect to the internet. i tried updating to a latest driver but nothing happens.. It actually detects wireless...
in your network connection, there is an Internet protocol(tcp/ip) double click it. put in obtain ip address automatically. same in dns server then ok.
If not work, configure it manually by using your laptop copy the ip addresses in your laptop, including subnet mask, and defualt gateway, and put it to your pc..
hope it can help you.
Dec 16, 2010 | TP-LINK TP link TL-WN350GD 54 / PCI / 11...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Jan 31, 2010 | Computers & Internet
Secury enable wireless network
the security is enabled on the router or access point noty in the wireless adapter,,, u can connect a comp to the router or accesspoint with a cable and access the page of the router or access point and disable security in it ,,,
Jun 03, 2009 | 3Com Officeconnect Wireless (303000011)...
Dec 10, 2008 | Symbol MC9090 Barcode Scanner
Symbol MC9090 Barcode Scanner Logo
548 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
