Question about Cooktops
Panasonic microwave oven Model no. NN-CS2003s/NN-c2002W
Hi!
I am facing frequent problem of microwave oven.
After cooking or boiling potatoes/lentil for 30 min.Microwave oven stop functioning. I checked the fuse it is working OK.The service centre is saying coil has gone. It happened 3 times in row within 6 months. What will be the probable causes so that I can fix the problem.It was a brand new product purchased from the Lulu store.
Regards
SOURCE:
  • 161 Answers
SOURCE: (2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
Posted on Jul 01, 2008
  • 222 Answers
SOURCE: Ultrex microwave won't start
hi gud day.did u have a manual to check before to try to operate, or u think the item is ok to use in ur country coz some model & brand have a diff in tecnical power,what HSN or ur unit is stock for how many years?sometimes this the coz of the problem.tnx
Posted on Feb 22, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Posted on Apr 21, 2009
SOURCE: lg microwave magnetron replacement
Thanks, the problem is fixed now, by replacing the
disfunctional magnetron with a new one. Thanks o
nce again
jijan
Posted on Jan 24, 2010
SOURCE: i have an old sharp microwave model r-8165, i need
I just got this microwave oven from my dad, with the manual included. Do you want me to copy it and send it to you?
Posted on Jan 19, 2011
Countertop micro getting hot
better get it down it does not have cooling to be built in
Jul 28, 2015 | Frigidaire FFCM1134LS 1.1 cu. ft....
My microwave keeps running
Thank you for your post, Lou!
From my understanding your Frigidaire microwave continues to run and when you press the second key your turntable will turn. This sounds like a potential issue with your keypad or control panel. I would recommend performing a reset on your microwave and you can do that by disconnecting power from it for at least ten minutes. This will help clear out any miscommunications within your microwave. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Jun 05, 2015 | Frigidaire Gallery FGMV154CLF 1.5 cu. ft....
How do I change the internal lightbulb?
Your owner's manual should show how. No manual, try manualslib.com
My old sears microwave light bulb is in the upper front left hand with bulb top up and socket down but behind a screen. There are screws to remove the upper fan apparatus, which appears to make the side available to extract the bulb. Probably a very special bulb, so I would get one before going to that trouble. It might also be the switch that is bad rather than the bulb. That probably requires removing the outer surrounding cover.
Apr 11, 2015 | LG LMVH1750ST Over-the-Range Convection...
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
Large section of dual burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
Instructions
Hi
I would gladly try to help you, but you do not mention wich brand and model the oven is, however they all work basicaly the same:
1. Punch in cook time. 2. Punch "CONVEC" 3. Punch a temperature button 4. Punch "START"
If you give me the brand and model number I may be able to email you the instructions for fee via email.
Hope this will help you.
Eddie Rentas
Tupper Lake NY
Jun 25, 2008 | Cooktops
Cooktops Logo
217 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
