Question about Haier HDN455 Dehumidifier
45 Pint Capacity, Electronic Control - 115 volt Dehumidifier HDN455E - No power
We used our Dehumidifier for less than a year and now it will not turn on. We tried multiple outlets that work with other things plugged into it. I see other posts similar to this one that suggest to send it in to get repaired. I don't think it's in warranty still however. Any suggestions would be appreciated.
  • Tannerman Oct 13, 2008
    Thanks - It turned out to be the fuse which was not that hard to get to. It was hard to find a replacement however through local hardware stores/car shops. Had to order it online - found mine via:
    www.apwagner.com
    AC-3050-02
    12AM 120V
    ordered a few thinking that it may blow again. Defective unit? Regardless, I'll go with the new fuse rather than purchase a new Dehumidifier for now.
    Thanks
    Works great now.
  • 3 Answers
Check the fuse on the board. If the fuse is ok
check Zener Diode ZD2 on the board to see if its shorted.
If it's shorted replace.
Posted on Oct 12, 2008
SOURCE:
Why wont it turn on?
if power is applied then display should show current room humidity , if set is pressed then display should show current set point for desired room humidity , this has to be less than first display otherwise the control will think room has acheeved desired setpoint and shut off , the one of these i had seemd to have an overly sensative collection bucket full sensor and had to be "just right" for unit to run
Feb 17, 2015 | Haier 45-Pint Dehumidifier
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | Haier 45-Pint Dehumidifier
My dehumidifier does not work at all anymore
I had the same problem with mine. I had it less than 2 years. The compressor seemed to kick on, but no water collected in the pan. the compressor should be covered for 5 years, but unless you have an extended warranty, there will be a service charge.
My dehumidifier was fried during a thunderstorm and nothing worked afterward, and it wasn't running at the time. I just bouught a frigidaire (45 pint) and I love it! no noise!
May 30, 2011 | Haier 45-Pint Dehumidifier
My dehumidifier does not drop any water into the drawer. I cleaned the filter and made sure the settings are correct. My basement has 67% humidity, according to the gauge. The unit is less then a...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 29, 2011 | Haier 45-Pint Dehumidifier
Dehumidifier is less than a year old. runs constantly but isnt collceting water. air filter was very dirty. cleaned it. now waiting to see if thats it or the unit is bad
heatman101
May 11, 2011 | Haier 45-Pint Dehumidifier
The dehumidifier runs for a few minutes and then shuts down. The humidity indicator shows that the humidity is 75% high in the room that it sits and I have it set for 40%. I'm thinking that it's a timer...
heatman101
Apr 12, 2011 | Haier 45-Pint Dehumidifier
My HDN455 45 pint Dehumidifier did not work
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2009 | Haier HDN455E 45 Pint Dehumidifier...
Haier HDN455 Dehumidifier Logo
230 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Bill Long
Evan Benson
Evan Benson
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
