Question about Dishwashers
Problem with whirlpool dishwasher ADP6000IX stuck on drain mode has err4 on it which means water inlet problem has sencer that changers to pump mode now is stuck on pump
  • Anonymous Sep 28, 2008
    I have the same problem!
Hi I had the same problem with a whirlpool adp6000ix. Although it looked fine from the inside, the base was full of water. I managed to fix the problem by pulling the dishwasher out and then tilting it gently to the side. All of the hidden water in the base poured out which cleared err4. It is now working fine. Tip: Make sure you have a couple of towels spread around before you tilt it. Good luck!
Posted on Jan 02, 2009
My dishwasher is leaving glasses cloudy and sometimes the powder doesn't desolve its 3 months old and the cutlery is streaked.
Posted on May 07, 2010
    Problem Solver:
  • 5 Answers
Yeah brahhz thats what happen to me then i was like no no no no no no no no no nno no no no no no then i saw this and was like yes yes yes yes ye yes ys ye yes ys yes yes yes
and that the story of my life.
Posted on Jun 01, 2010
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Whirlpool ADP8540 IX dishwasher - dishwasher starts then stop shortly afterward Error light flashing 4 times. I can restart by holding the start button but shuts down again shortly afterwards - Any Ideas??
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Need to check the inlet valve, the pressure pump as it seems to trip the controller unit.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Aug 18, 2011 | Whirlpool Dishwashers
Water does not flow through the drain
hello,
~Check for hose kinks or food plugging drain hose.
~Check pump impeller for damage
~Check pump motor for reversing during the pump out Make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
~Check timer for not letting the dishwasher pause.
~If you have recently installed a new garbage disposal, check knock-out plug at connection.
~Check the check valve and drain hose for debris.
~Check that the water inlet valve isn't seeping fresh water into the dishwasher when off. (if yes, replace the inlet valve).
thanks
May 21, 2011 | Home
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
My whirlpool dishwasher will not start. It beeps, drains & flashes Err4 on the screen.
If you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completely) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone!
Sep 28, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
I have a whirlpool DW ADP6000AH - Err4 keeps flashing, how do I fix this?
unplug the hoses, tilt the dishwasher backwards, until all the water drains out
Dec 24, 2009 | Dishwashers
NOT WATER COMING THROUGH TO MY DISHES IN MY DISHWASHER ADP6000IX
If there is no water at all , check the following:
Inlet hose.
Ensure that there is sufficient pressure, and that the hose is not kinked.
Water level device.
Usually a float switch. Ensure that the switch is working and that sensor is not stuck.
Inlet valve.
Test if inlet valve solenoid has continuity and if the valve is opening and closing.
Door latch.
Test door lock switch.
Electronic control
If all the above is OK, then it is usually a faulty control.
Test also the wiring harness.
Dec 01, 2009 | Dishwashers
NOISY DISHWASHER WHIRLPOOL GU3600
If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Jul 24, 2009 | Whirlpool GU3600XTS Dishwasher
I have a whirlpool water softner. After regenerating, the water is still hard and the tank is about half full of water. I have cleaned the venturi.
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Dec 06, 2008 | Whirlpool Dishwashers
Err4 came on drain clogged..have fixed but cant get error to stop
hold the start button in for at least 3 seconds and it should reset
Dec 14, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
1,655 people viewed this question
Top Dishwashers Experts
