Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 How do I stop my Hotpoint WD860 leaking from my detergent tray ? Thanks in advance
  • michelle1617 Aug 13, 2008
    Yes I have the same problem. I think I know the cause as inside the drum one of the drum paddles broke and i had to get a replacement but some small items had gone through the gap where the paddle came off. I thought I had managed to fish everything out but obviously not because after replacing the drum paddle my machine now leaks from the detergent drawer during the last 10 mins of the cycle. There must be something still in there causing a blockage. Does anyone know if it is easy to take the drum out to see what is blocking it.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
Posted on May 06, 2010
  • 639 Answers
ngfam1 here for you!
I am happy to be of assistance!
It is not easy and I feel you should call service to have it done correctly!
Sounds like you need both knob and screw!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
quit using powered detergent .we quit many years ago as it does not dissolve properly in our hard water .no problems with liquid .
Oct 16, 2015 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMF720 Aquarius+
Hotpoint WMF720 Aquarius washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 28, 2012 | Hotpoint Washing Machines
Hotpoint ultima wd860; My washing keeps coming out smelling musty even though I use conditioner regularly. Is ther a filter I need to clean out. Thanks
you need to clean the draw and the inside of the draw and clean the rubber door seal all way round when you done that use a washer clean detergent whitch should be at a super market. and run it at 90 or 95 temp cottons wash it should stop the smell beacause dirt is buliding up so a good clean should stop it.hope this helps.
Sep 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Feb 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
F7 fault code on Hotpoint WD860
Fault code F7 is a heater relay fault
Sep 25, 2008 | Washing Machines
Changing the door gasket on Hotpoint Ultima WD860
Managed to work it out myself how to take the old door gasket off and attach the new one. Thanks. Machine working okay with no leaks or mould anywhere now.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
509 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
