Question about Dell Dimension 2400 PC Desktop
No shutting down
I bought this computer as a refurbished unit. it had the drivers but no operating system. i installed xphome. it worked fine till i put a disk in that is called system suite8. this program diagnosis problems with the computer. it fixes registry problems. since i fixed the registry, it will not shutdown. it just keeps rebooting when you click the icon to turn computer off.
thanks for your help
  • ccb37s Aug 09, 2008
    I thank you for your expertise but I needed to do something to get it going couldn't wait any longer for a solution. So I reinstalled windows again, than I had 3 os showing to choose from when booting up. When I went into uninstall programs, they did not show up. So I did the worst. I partitioned the drive and wiped everything off. Now I can't get it to install the os or anything. It states non system disk phrase and that is it.
    So I am worse off now. Now WHAT!!
  • 16 Answers
Uninstall the program, go to download.com and grab spybot, and AVG anti virus.
Once you have installed spybot, let it immunize your system, 100% do a full reboot, do it again, then do a system scan, quarantine everything. You will see a BUNCH of popup windows editing your registry, do not be alarmed, spybot is removing the hijacker programs from the registry(nothing in your registry should redirect your operating system except microsoft official programs that specifically say microsoft on them, in the microsoft directory trees, which are extremely long due to their own "big brother" techniques)
Now once SPYBOT is complete, immunize 2-3 times, to be sure, reboot, do it again, until nothing shows on the 2-3rd boot.
NOW your registry is somewhat functional. NEXT
Download AVG antivirus, do a FULL install, dont custom anything, unless you are a professional network engineer and know your Operating System 100%. Once installed, do a full system scan, it will show, most likely 2-3 items non critical, those are most likely web cookies/java cookies, that hijack, quarantine them. Then if more shows, quarantine them. REBOOT when it asks you to, if it doesnt, reboot anyhow, do it again. BAM BAM BAM!
I hate to tell people this concept, that rebooting helps the FREE programs go into your HIGH RAM BIOS at your system startup and intercept these rogue warez that surface.
Get your programs from download.com and try them out, before you go to a website and use a suite program that says "we can fix it all!!!" Most likely, they are rogue ad-ware/spy-ware/hack-ware, under warez. Download.com uses no programs of the sort, and notify you if the program comes with it.
Long story here, but it should get you through the shutdown issue, if not, its time to overwrite your operating system registry with a fresh and clean unit(reinstall windows), or build a partition with your windows backed up in it, or last you can create a restore point for your windows and go back to when it worked.
Do what you can, within your tech knowledge, and tell me how it goes.
ManOwar
Posted on Aug 09, 2008
I need to reinstall windows xp home edition i have the product code but no disk
I have used full install/ disk from other brands of computers (or other dell model numbers)to reinstall operation system (must be winxphome, dont worry about service pack, you can update). If you use any dell reinstallation cd, most likely you will not have to enter your key. If you use any other computer brand, or borrow someones xphome full install disk (not upgrade), then you will need to enter your key. Only problem of using for example emachine full install disk is that is will have emachine themes. Also you will likely need to down load other drivers. You are not lemited to to using reinstall cd for your model number. Good luck
Aug 28, 2012 | Microsoft Windows XP Home Edition Service...
Geforce 8500 GT Causes "Snowy" screen
You have Vista 64 bit right? I looked and the newest nvidia driver is 182.08 located here:
http://www.nvidia.com/object/winvista_x64_182.08_whql.html
1. Download this driver.
2. Go to the Control Panel, Programs and uninstall the current nvidia driver.
3. Shut down computer.
4. Remove video card and re-install it.
5. Start computer and install new nvidia driver.
Mar 11, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
My computer keeps restarting why??
HI, your system has contracted a nasty virus that has destroyed a vital system 32 file that is needed for stability. You will have to preform a restoration to bring back stability and continuity. A good way to do this is to use the system restore disk that should have been delivered along with this unit. if you don't have this disk, you can use a Windows Xp install disk as well. be sure to wipe the partitions and reformat the drive to rid the system of this horrid virus attack.
Mar 09, 2009 | Gateway GT5056 PC Desktop
Possible operating system and motherboard incompatability
Probably, I would either buy and XP disc, or download one off the internet using utorrent, then isohunt.com. And having just SP1 leaves you open to worms, viruses, trojans, and etc. Also make sure your BIOS is up to date too.
Jan 23, 2009 | Intel Motherboard
Installing a hard drive on the eurovox ex5000 pvr stops it workin
if the hard drive is new and not formatted , there will be no operating system for the computer to go past the bios start up
what you will have to do is to get into the bios , select boot preference and select cd as first preference
load an operating system( example win 8) and let the unit boot from the disc
after that has properly installed ,shut down the unit , restart and get the bios back up and change boot preference to hard drive
from then on it should start and boot from the program on the hard drive
Nov 13, 2017 | Televison & Video
Computer loading
AS what you have said computer start over and over again. this was due to the system conflict or hardware conflict.
The solution of this is to restore all the setting by completely restoring using the installation disk.
Or reinstall the windows operating system.
procedure in windows installation can be found here:
http://support.microsoft.com/kb/316941
Hope you do this in order, please tell if whatever happen.
melnavz
Oct 04, 2008 | Compaq EVO D5S SFF Refurbished Desktop...
Acer laptop aspire 4710z config my notebook have problem
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Install canon pixma mp510 - don't have disks
Go to website http://software.canon-europe.com/ - type in your product on the right hand side , then language and operating system on the next page, then scroll down and download mp drivers, then run these - your printer should now install.
Just tried the site and it is down at the moment, it worked yesterday; give it 'till tomorrow night - should be fine by then.
Jan 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Monitor Shutdown problem
I believe the problem is from the herzian synch windows wants to achieve, either too low or too high.
You ought to try with a different monitor, either to set the synch or to make a analasys if it's another problem we're facing, like graphics card or motherboard itself.
Nov 15, 2007 | ASUS A9550GE/TD Radeon 9550 Graphic Card
Dell Dimension 2400 PC Desktop Logo
59 people viewed this question
Alun Cox
