You should use a router instead of a switch...however if you still want to use the switch, request your service provider to provide two ip addresses, instead of regularly just one...but you mostly like need to pay monthly the extra ip address...alternatively ask your service provider to upgrade your cable modem to cable modem with router capability, ...
SOURCE: d link des-1005d
do a factory reset. see if that helps. Check IP mapping, make sure the two PCs are on different IPs
SOURCE: d-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
SOURCE: How to get connetcion using D-Link DES-1005D / DES-1008D
go to folowing link you will get all information for D-Link DES setup
http://software.informer.com/getfree-d--link-setup-wizard-download/
