Perhaps if you got a paper when you try to remove jammed paper to a piece of paper rupr remained on paper route, and have seen where, if paper was not broken when it is possible that when you pulled a paper to be skipped sensor that never returns to the starting position
How do you return a skipped sensor to the starting position?
If you discover that it is a defective sensor, jumped to first place check is not anything broken, damaged. Toul If it's ok, you should be a spring that makes the return sensor spring position is initiala.Acel fixed, the ends of the arc is put on a special place to sit as a bolt fixed. moving carefully back into position to rest initiala.In it's skill, good luck! (sorry for my english)
