Question about Sony Ericsson Cell Phones
Phone turns itself off randomly. memory card in or out makes no difference. occured since software reflash to facilitate network unlock.
  • john shack Aug 07, 2008
    regardless of where the phone is, wether it is static or stationary, in call or idle, playing a game or music, my phone will just go off. not shutdown but go blank and require turning back on. as if the battery had been removed. i am currently trying out a bit of cardboard shoved under the battery to push it against the contacts.
    it still goes off with a gentle knock tho.
    dunno what more info i can give you beyond that.
  • Suvvy Roy May 11, 2010
    Could you please provide some more information. I have had similar problems with my phone, and I suspect it is not due to software reflash
    Champion:
  • 221 Answers
I was looking for a phone model :) however, let me give you a few troubleshooting steps;
1) (this may not work depending on your phone model) take out the battery, and plug in the charger by itself. If the phone turns on and everything, and STAYS on, you have a problem with your battery, but like i said, many phones don't like to turn on without the battery 2) if someone you know has the same phone as you, you can borrow their battery, and see if it solves the problem 3) if you think the battery is a problem, then take it to your service provider's store, and they will replace it for you. If your phone is defective, they can help you with that as well.
Posted on Aug 10, 2008
No service(network) on my BB 9630 phone
Try to unlock your blackberry network using blackberry tour 9630 unlock code for your original network sim card. Example : if your original network sim card at&t, use blackberry unlock code for at&t network. If your network still no service signal, reflash your blackberry phone.
Aug 09, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Tengo un problema con la impresora hp modelo m4345 mfp, la cual ya estaba funcionando pero de repente envio un error el cual es el siguiente 49.4c02 - error para continuar apague y encienda , ya lo...
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Jul 14, 2011 | HP LaserJet M4345 MultiFunction Printer
I am unable to access any of the blackberry services on my bold 9700. my carrier suggested that as the phone has been unlocked that i need to reflash? can you advise
Try to unlock your phone using blackberry bold 9700 unlock code network from your original sim card. If your phone already unlocked you didn't need reflash process, blackberry unlocked phones can use any other network sim card whenever you put that sim card on your phone.
Jun 09, 2011 | RIM BlackBerry Bold 9700 Smartphone
I go to set a picture as my screensaver and it says assignment failed due to insufficient phone memory?
transfer your files including images,videos,music files to your memory card,if the problem still occur,your cellphone might be corrupted and needs software reflash and update.
Aug 21, 2010 | Cell Phones
Formate nokia 5530 if forget secuirty code
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Jul 22, 2010 | Nokia 6500 Slide Cellular Phone
I have a Samsung F480 and I am getting my screen freezing and I can only fix it by taking the battery out. Is this a known fault of this model?
it is an issue not only to samsung phones but the other brands and model as well.
to give you an idea, the causes of phone freezes are.
1. firmware failure
2. low phone memory capacity due to some big files were saved to phone
3. errors on your memory card(i.e; not formatted through cp or formatted to pc instead of your cp formatting utility, etc)
4. deleted file system for your phone or relocations of its strings
5. deleted or modifications on the registry
6. other applications are running on backgrounds.
7. sim errors or the phone is having difficulty to recognize the it.
many more...
to help you fix the problem try to do the steps.
1. back up your phone files, examples are, contacts, messages, mms, notes, task, etc through your samsung pc suite.
2. switch off your phone.
3. remove your battery
4. remove your sim and memory card
5. reinsert your battery and switch the phone.
6. from your keypad menu, type this code*2767*3855# to factory reset your phone and erase or fix the errors encountered by it.
7. switch off your phone, reinsert your sim and battery and switch on play with it first by setting and configuring it and check.
8. if your sim doesn't give you any lagging or freezes, switch it off, and insert your memory card and check.
after a successful factory reset had taken place and your problem was not fixed.....troubleshooting steps.
note 1. if this doesn't fix your problem, try to remember what you have done lately to your phone.
example of it is, unlocking to all networks by the use of a patch, or reflash. if this was what you have done lately, try to go back to the one who unlocked it and have him reflash the firmware or the latest version of the firmware for your phone.
note 2, try a different sim check if lagging and pauses occurs. if not then your sim has the errors.
note 3, remove the sim and insert your memory card, if lagging and freezes occurs, there's also a problem in your memory card. you may want to insert it to your computer and run the virus scanner from your pc. and reinsert it after the virus scan and check.
note 4. after factory reset had taken place, and the phone restarts and without sim and memory it gives you the same problem, go to your nearest samsung service centers, you may be needing a firmware upgrades or firmware reflash.
regards..
Mar 03, 2010 | Samsung Cell Phones
Start up screen/Shut down screen
Even thought your phone is unlocked from virgin the software is still a virgin viewity software. your can try and press on the arrows <<<<>>>>> at the bottom of the screen when the come up this will allow you to remove the network label but not on startup that requres a mobile shop to reflash the phone with generic software which will cost up to £25 shop around
May 27, 2009 | LG KU990 Viewty
I can't turn on my phon
It's likely that you need to reflash the phone software to your phone. You can do this yourself  or just do it at a phone shop or through an online site like Da Vinci or Wontan.
But something you should try is to remove the battery and take out your SIM / memory card and then let it sit for a bit before you reinsert the battery [withouth SIM / memory card] and restart the phone. Hopefully that'll work, if not then you'll probably have to reflash the phone software.
Apr 13, 2009 | Sony Ericsson w580i Cellular Phone
Memory card not shown on nokia 5200 .what is the problem
try another card if the same problem occurs then you will either need to change the board or have i reflash or you can also clean the contacts on the phone memory card slot.
Aug 23, 2008 | Nokia 5200 Cellular Phone
My Samsung U600 will not transfer images from my memory card to my phone to use as a wallpaper etc. It keeps stating that it has failed. It also will not take pictures if I have to store to the phone...
'uve said that they upload the latest firmware., send it back to them and tell them that the firmware they put was'nt match for your fone..they have to put the same version and flash it to your fone not using your firmware, probably they use ur own software..and it also was faulty, they have to try to downgrade it to work properly., or try a lot of firmswares to macth and and they have to observe it first before givin it back to you.. .. if its still the same.... probably ihe problem is you ram ( random acces memory ). it's faulty and have to replace or repair it...tnx
Apr 17, 2008 | Cell Phones
Cell Phones Logo
43 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
