Question about Sonance Sonamp 1230 12-Channel Amplifier
No sound from my 1230
Hi ,i have a 1230 sonamp that appears to have power the led's come on and the remote switching lights up but there is no power fed to the amps !
there r no channels a in fault condition.
can anyone please help me with a circuit diagram or some hints where to test ? i can fault find with a diagram.
thanks guys.
my e-mail address is [email protected]
regards joe.
  • grover57 Dec 26, 2008
    I have the exact same problem. Amp has worked fine for about two years, then just stopped working. The green and red LED's are both on as normal, and no protection LED's are on, but no sound. When the amp is turned off and back on it no longer goes through the 3-second amp stabilization/protection cycle. Any help would be appreciated!
  • grover57 Jan 02, 2009
    I have spoken with Sonance technical service. They say it sounds like a relay is out and I am sending to them for service. The quoted price for service is extremely reasonable, though shippping this monster will be expensive. I'll report back if there are any problems.
SOURCE:
  • 54 Answers
SOURCE: Sonamp Set up
Tape out from dennon to tape in on sonamp then select source from dennon.
GOD LUCK
BIGRED
Posted on Apr 02, 2008
VOTIT
  • 2071 Answers
SOURCE: my sonamp 1230 seems to
Try to check if the blower is working, If not then first look for the blower sensor and clean it and resolder parts pin joints and associated parts also.If ever the blower is working fine then the problem is in amplifier section caused by change value resistor or leak capacitor or cold ,loose or crack solder joint parts this the common problem of over heating amplifier caused by abnormal distribution of current,try all of this,so your receivers works normal again.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 07, 2009
  • 6 Answers
SOURCE: sonamp 260 no sound
1. Check that the trimpots on the front panel are all the way up.
2. The speaker relay on the Amp PCB may be bad. Over time the fingers can warp and won't make contact any longer.
Posted on Aug 14, 2009
  • 128 Answers
SOURCE: purchased 2 used sonance sonamp 260 for homewide
I am assuming you are using the standard sonamp 260 not a 260x3
and that when you say you are getting sound on only 1 pair that means only on 1 side (left or right channel only?)
Are using a speaker selector box? you must to regulate the resistance (ohms)
if so first unhook all but on pair of speakers and see if both channels are working.
if they do your problem is in the speaker selector not the amp if no then check to see what the amp level is set to. These are the two small holes on the front right of amp make sure they are set about equal at around half way up.
If that doesn't work flip the RCA cables coming to the amp perhaps you have a bad cable if that doesn't work make sure your receiver (source) is outputing a stereo signal to begin with.
lastly 8 sets of speakers off 1 amp? that's pushing it.even with a high quality Niles or speakercraft selector that controls the resistance going to an amp I wouldn't go past 5 sets.
The right way to do it would be to use 260x3 or a sonance or speakercraft 12 channel amp.
Posted on Jan 15, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have 2 Sonance Sonamp
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=Sonance+Sonamp+260
It's not bridgeable according to the manual.
Who specs an amp at 3 ohms anyway? Your Carver might be just as effectively powerful.
Posted on May 01, 2011
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
I have a Sonamp 260 MKII. The red light is on but the green light does not come on. I've unhooked all speaker wires and input wires. Now what?
The red light will stay on without speakers connected.
Make sure your speakers are good and try again
If it still fails then there's a power supply failure internally
Aug 02, 2010 | Sonance Sonamp 260 MKII 2-Channel...
Sonamp 260 no sound ac on light stays red power on light is green
May 23, 2009 | Sonance Sonamp 260 MKII 2-Channel...
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
Printer reset re Brother HL 1230
Resetting the printer should clear the flashing leds (flashing lights.)
How to Perform A Factory Reset:
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button. Hold in
the circular button on the front panel again. Once the Alarm light comes
on, let go of the button. This has performed a factory reset on the printer.
If the alarm continues, the printer may need service.
This issue is listed by Brother. Click here to view
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 22, 2007 | Brother HL 1230 Laser Printer
Sonance Sonamp 1230 12-Channel Amplifier Logo
134 people viewed this question
Top Sonance Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Sonance Audio Player and Recorder Expert? Answer questions, earn points and help others
