Question about Wizoo Darbuka
Connection code how to connect msaccess database through c++
    Scholar:
  • 40 Answers
_ConnectionPtr con; cn.CreateInstance(__uuidof(connect));
OLEDB cn->Open(L"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\\database.mdb;Persist Security Info=False","","",adOpenUnspecified);
ODBC cn->Open("Driver={Microsoft Access Drive (*.mdb)};;Persist Security Info=False;Dbq=C:\mydatabase.mdb;Uid=Admin;Pwd=;)
I hope this helps.
Thanks, Raphael
Posted on Jan 24, 2009
SQLCE database connection problem on MC1000
Try disposing your database object properly by making use of the using keyword.
Uunless you need your connection open. But it is not recommended.
Jun 15, 2013 | Symbol MC1000 Barcode Scanner
Example sorurce code for database
Hello my friend try this code: This code is design for Visual Basic 6.0
Function for Connection and recordset string.  '========Connection String====== Public Sub connection(ByRef dConnection As ADODB.connection, ByVal dLocation As String)     dConnection.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dLocation & ";Persist Security Info=False;" End Sub '======End of Connection String======
'=======Recordset String=========== Public Sub recordset(ByRef sRecordset As ADODB.recordset, ByRef sConnection As ADODB.connection, ByVal sSQl As String) With sRecordset .CursorLocation = adUseClient .Open sSQl, sConnection, adOpenKeyset, adLockOptimistic End With End Sub '======End Recordset String========
How to apply the above function? Application:
'====== Command Save Button======== Private Sub cmdsave_Click() Dim cn3 As New ADODB.connection Dim rs3 As New ADODB.recordset
Call connection(cn3, App.Path & "\CASGC.mdb") Call recordset(rs3, cn3, "Select * from Debtor_Creditor_Account") Set dtglobal.DataSource = rs3.DataSource
With rs3   .AddNew   .Fields("Code") = txtCode.Text   .Fields("Description") = txtDescription.Text   .Fields("Tag") = cbotag.Text   .Update   .Requery    End With   MsgBox "New Account has been Added", vbInformation   Set cn3 = Nothing Set rs3 = Nothing
End Sub '=======end of Command Save button=====
The advantage of using this code is setting your database connection is you have a reliable connection towards your database where ever you place your database you can you don't to remount you databse connection control. Also you are no longer need to use a ADO control or DAO control just copy the function and paste it in your coding area and call the function and you have now a working database and recordset connection string.
For more details regarding how to apply this code just email me at this address: geo_jonas@yahoo.com to get more codes. thanks.. Please rate this Solution.
Jul 08, 2009 | Microsoft Visual Basic 6.0 for PC
I can't add data in the database using vb
The database can be any like oracle.
Two type of connection u can make.
One of such connection is ADODB
The code is like
Dim ors As ADODB.Recordset
Dim oconn As Connection
Dim Qry as String
dim Qry1 as string
Set ors = New ADODB.Recordset
Set oconn = New ADODB.Connection
Chk_selectall.Visible = False
oconn.Open "Provider=MSDAORA.1;" & "user id = " & Username & _
";password = " & Password & ";data source = " & Conn_string _
& ";Persist Security Info=True"
Qry = "insert into table1 values (100,'we')"
oconn.execute "Qry"
If u select any data then u ve to use
Qry1 = "select * from table1"
ors.open "Qry1",oconn
do until ors.EOF
msgbox ors(0) & "," & ors(1)
ors.movenext;
loop
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
How to connect 3 tables ang get report
You would create relationships between your tables assuming there is a correlation in the data you are using.
Feb 15, 2009 | Microsoft Computers & Internet
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
Ms access
Microsoft access is a database application that is part of Microsoft Office. It lets you edit .MDB database files. Installing Access also installs the drivers that allow other applications which use the MS Access database format to also open their databases as well.
Not sure what your question means. If you want more information please ask me before rating the solution.
Jan 31, 2008 | Microsoft Windows XP Professional With...
C database with formdesigns
You are at least by looking at what you are trying to do familair with far more than the average user. On the other hand you have not supplied the names of what you are doing or as good a description of the problem as might be necessary to pose a meaningful solution. SO....my suggestion is you check faq's at your suppliers website, google the internet with your specific problem, and go to your O/S suppliers website (i.e. the Microsoft knowledge base) for more help.
Jan 18, 2008 | Computers & Internet
VGA port problem
That could be a video card driver issue. It seems that when the projector is connected, windows detects it a create another screen using up more memory. Try download a latest video card driver for your laptop http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/1rd635ww.exe this is for Windows 200/XP for the IBM Thinkpad T42. If that doesn't work then you should also try updating your operating system. Hope that helps!
Sep 11, 2006 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
161 people viewed this question
Top Wizoo Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Wizoo Computer and Internet Expert? Answer questions, earn points and help others
