Question about Mitsubishi WS-65807 65" Rear Projection Television
I have a mitsubishi ws-65807. I have no picture or sound. It used to work.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Try the self check this model has, try to turn set on and when green power light comes on and goes off press and hold both the menu and input buttons on the front of the set at the same time for at least 5 seconds and then release both buttons.
This is a self-check this model has----the power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
The idea here was to narrow down what area the problem is in.
Let me know with a comment here and I will tell you what the error code you found means.
SD TECH
Posted on Apr 12, 2011
SOURCE:
Add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Dec 13, 2012 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 Won't turn on....
it could be the bulb the lights u are seeing should be green not red.
Jan 14, 2009 | Mitsubishi WS-65807 65" Rear Projection...
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws 65807 sound with no picture
push qv and 9 on your remote and a screen will come up and follow the directions to correct your problem.
Jan 05, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws 65807 RED CRT
What I usually find on sets like that is that there is a loose solder joint on the CRT board itslef. You must get to the bottom of the picture tubes, pull off the CRT board from the red CRT and examine all solder joints on that board. Chances are one or more will be cracked, and resoldering all joints on the board should clear up your problem.
Aug 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
TV Image bending
maybe you have a magnet near it?
Feb 26, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
