Question about Kodak EASYSHARE 5100 All-In-One Printer
Black Ink not printing
My black ink will not print at all. I have ran the cleaner several times. Have replaced the cartridge 3 times ( with a new one), still nothing. I am using alot of colred ink due to not having the black, must convert everything to color...I recieved a message from Kodak to remove the printhead and reinstall, I can't get it out, and can find no instructions on how to remove it. Can you help!!!!!!!!!!!! Getting frustrated the printer has been replaced once all ready.
I love the print quality when it works........Searching for answers or a new printer.
Thanks,Vicky
  • becker_lyrae Aug 08, 2008
    Similar issue with my 5300 in that I cannot get a text document to print, whether in color or in black. Calibration, printhead cleaning, and removing/reinstalling the cartridge have failed to correct the problem. Moreover, each time I attempt to print (in black, hoping each outcome will be different), the dialogue box illustrates that my (black) ink level has reduced by a considerable amount, so that even though no ink's been spilled after a dozen printing attempts, I am now being prompted to replace the cartridge!
    That's a problem. But the other problem is that I'm not assured that a new cartridge will correct it, at least not the first new cartridge. I had a similar issue with printing a couple of weeks ago but it was due to the color cartridge. The color needed replacing, but I simply wanted to print a text document in black, yet the printer indicated it would not print in black until I replaced the color cartridge. When I finally gave in and replaced the color cartridge with a new one, it still refused to print, and continued to prompt me to replace the color cartridge. When I installed a second brand new color cartridge, it inexplicably started to print as usual. Until now.
    Keep in mind, that's more than twice the cost in ink that Kodak promised I'd use, at twice the cost, and even more than that when you factor in the fact that I got NO prints out of the first color cartridge I replaced! (It's still sitting here, brand new, but now opened. What am I supposed to do with it?)
    I want to know a couple of things:
    1. Where's Kodak tech support (offered by Kodak Co.)?! I don't have all day to peruse all the hits in a search--a Kodak Co. site should appear on the first or second page. Barring that, I would expect to find a toll-free number to call somewhere in the program or in the manual, but have found none.
    2. What's Kodak Co. up to? Is this a built-in glich to make money on ink? After all, I'm apparently not the only one with this problem. I smell Class-Action!!
  • kungpow Aug 10, 2008
    Having the same problem -- Did all the calibration and print head cleaning to no avail - - called Kodak as suggested -- after about five minutes of retrying everything I had just done, they got me to read out the serial # on the print head and then said that they would be sending out a new print head and inks (5-7 business days in Canada) Glad I read this - Thanks
Call this number. I had the same problem, and Kodak is replacing my print head FREE of charge. As the printers in the 5000 series are still under warranty. 1 800 421 6699
(To remove your print head: first remove the color ink cartridge. there is a button of sorts under a small ledge just above the picture of the finger used for installation. Press FIRMLY here, up towards the ceiling. The print head will come out. To reinstall, just put back in and press again firmly on the pic of the finger till it snaps.)
If you get the same quality of print, you need a new head.
Posted on Aug 10, 2008
Mg7120 won't print black on paper,but will print pictures with black just fine
It looks like you may have 2 black ink cartridges; one for black-and-white printing, and one for color printing. The larger one may have clogged nozzles. Run a cleaning cycle several times, and see if that solves it.
Other options which would be entirely at your own risk:
1. Dabbing the print nozzle head with warm water on a cotton swab.
2. As above with a mild solution of rubbing alcohol.
3. Soaking the print head overnight.
4. Applying vacuum to the print head.
Feb 11, 2017 | Black Office Equipment & Supplies
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MFC 790cw will not print in black.
garetg,
Your issue with the black ink only is because the print head my be dried up. Witch me that the ink cant flow to the "paper" fast enough. So by time to rollers eject the paper, the ink cant print on the paper. I had the same problem with my Kodak EasyShare 5300 All-In-One. So I contacted Kodak and they are sending me a new one. Try doing the same. Contact your manufacture and ask them..... :)
Much Regards,
Kyle
Sep 16, 2009 | Brother Multi-Function Center MFC-240C...
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
135 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
