Question about Belkin USB PDA Adapter (F5U109EA) Serial Adapter
I have a Belkin 1GB USB data stick. I have damaged the connection. I have been told that it is impossible to repair or retrieve the data. My life is on it! I need the data urgently!!
  • maggieburns Aug 07, 2008
    the number on the stick is F5U126ea1GB it has a serial number 050305800. I knocked the stick while it was in the port and have bent the connector
  • 567 Answers
Hi there
Your best bet would be a professional data recovery firm - it'll be expensive though,
the memory chip need to be take out from it and soldered in a new identical data stick, and hope it works long enough to get your data off.
dont try to do it yourself you will need professional help that too depends if the memory chip itself is not damaged
hope this helps
Good luck
Posted on Aug 07, 2008
  • Belkin Master
  • 19,396 Answers
If it is only the connector it is not impossible to fix. Usb has 4 connectors, here is
USB pinout All you need to find is a local electronic repairer good at soldering, and ask him to solder the 4 usb connectors on the small board inside your data stick to an usb cable, following the pinout above. Eventually give the repairman a printout of the
USB pinout page.
Regards
    Champion:
  • 221 Answers
A: if you want to take a risk, try bending the top of it back to it's normal position.
B: You might want to open it up and check for internal damage. Most flash drives are held together by a screw or can be **** open with a penknife. Bend the plug back to it's normal position, and try putting it back in your computer. If your computer picks it up, copy off all the data, and buy a new flash drive!
If that doesn't work, contact a data recovery specialist in your area, and they will be able to help you! Good Luck!
Sony memory stick is damaged n i wants to recover my data from memory card is it possible?
once USB is damage there is no way to retrieve data from it. but you can try to get all data using DOS command.
Sep 11, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
Retrieving data from dead hard drive
Retrieving data fromdamaged hard disk is possible. There are companies that can remove the diskplatters from the damaged hard drive and with special equipment may beable to recover your data, but it will cost you an arm and a leg for theirservices. The reason for this high cost, they dismantle and remove the plattersin the hard drive in a clean room environment and set up the platters up injig/drive to retrieve/copy the data. First thing I would try isto remove the damaged hard drive and connect it to an USB hard drive adapterand then plug this adapter into a working computer's USB port. If thiscomputer sees this hard drive as an external hard drive and you can open thevarious folders and files, then I would backup your data. If the hard drive is notdetected then the hard drive is dead and data cannot be retrieved with thismethod.
Aug 14, 2011 | Computers & Internet
How to recover data from my damage hard desk
Recovering data from a faulty or damaged hard disk is impossible for users, it requires specialized tools and knowledge.
There are companies that specialized in recovering data from faulty and damaged hard drives BUT it will cost you an arm and a leg for their services.
If you still wish to retrieve your data then Google search for data retrieval companies.
Jan 16, 2011 | Computers & Internet
How can i retrieve my files from a broken memory stick pro duo
It depends how it is broken, if there is a physical reason, broken connection inside, then it will be possible but if the ram chip inside has died then sorry you've lost it all.
If the chip itself is not damaged, then the data can be recovered.
It will probably cost you money, so it all depends on how important the data is.
It is unlikely that you will be able to do this yourself, but there are companies out there that specialize in recovering data from damaged drives.
Apr 27, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
How to repair a memory stick duo turn that to raw
Put memory stick in camera and format it, this is the only way to fix some problem in memory stick.
If that does not help, memory stick got hardware problem that is irreparable. Buy new memory stick then.
Thanks.
Nov 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Laptop is dead; can I still retrieve data from hard drive?
You can remove the hard drive and connect it to an USB hard drive adapter or an USB hard drive adapter case and connect it to a working computer's USB port. If this computer sees it as an external hard drive then you can copy your data off this hard drive. If it doesn't see the hard drive, then it is faulty. There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
If the hard drive is OK you can put the hard drive into an USB hard drive adapter case and use it as an USB hard drive.
Sep 27, 2009 | Dell Inspiron 1000 Notebook
1GB Micro Vault Ultra Mini USB 2.0 Flash Drive not formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Pqi 1gb usb flash disk
2. Format
Jun 11, 2008 | PQI Intelligent Stick (267027) Hard Drive
Belkin USB PDA Adapter (F5U109EA) Serial Adapter Logo
102 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
