Question about Neff Microwave Ovens
We were flooded last year, and our neff microwave was removed from a housing tower unit. We would now like to place it back into a unit above a steamer. We are unsure how to refit it. It has a steel shelf which the surround attaches too. Does this go above or below the microwave? Does it need to be fitted onto a shelf? Also there is a plastic container, where would this go? Is it necessary and why? The microwave modelnumber is H5642.
  • Neff Master
  • 9,098 Answers
You can download Neff manuals here.
Posted on Aug 10, 2008
I am having difficulty in obtaining access to the bulb .
Hi
You need to unscrew the holding screws and slide the whole unit out of the housing, there is a small plate on the top panel held with two screws remove those and the bulb is in there
May 06, 2011 | Neff H7871N2GB Convection / Microwave Oven
How do you change the interior light. I cant see an access panel either on the outside or within the unit
I think on that model the whole outer casing needs to be removed. These bulbs are designed to last but appearently this one got by them in the inspection department.
Hope this helped you
Dave
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Microwave turns itself oo
it sound like the inverter unit is faulty or the magnetron is gone.the only real way to find out which is to change each one in turn,sorry i cant be any more help.if you have any more questions get back in touch,regards les
Jul 28, 2009 | Neff Microwave Ovens
Microwave lights up and glass plate rotates but no heat. Also, unsure how to remove microwave from its surround within kitchen unit.
to almost all of the no heat microwave issues suggest calling company about warranty because the warranty may cover problems like these up to five years and taking them apart will almost certainly void it. Magnatron is likely cause for problem.
Apr 21, 2009 | Microwave Ovens
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
NEFF H5632NOGB/01
Open door, place hands in centre of roof, lift gently and move back. This reveals four screws that mount the frame to the outside wooden housing, remove these and then remove the frame. Now lift the microwave out of the oven housing.
Dec 14, 2007 | Neff H5642 Convection / Microwave Oven
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Dec 11, 2006 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
134 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
