I imagine you have the installation instructions since you just installed it. Your new shower handle has a hot limit safety stop. You can set this with a flat blade screwdriver. The safety stop is the red ring in the handle and all you need to do is pry the ring forward with the screw driver and rotate it clockwise to increase your hot water.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
I already did that, doesn't work.
I have good pressure everywere in my house.
When I put the handle on the cold side, I have really good pressure. I turn the handle for hot water and the pressure stop and I have very low pressure.
Hey Andre,
I don't believe you can take the cartridge off. If you do, you lose the stem. Usually we just replace the valve with one without stops. The valve without stops is the R120 and the one with stops is R120SS.
How is the hot/cold balance when you have the faucet on full hot? If it's perfect, then possibly you should adjust the red ring for hotter water. That would increase the flow of hot water and decrease the cold water. Just a thought....
Handie Andie
Where in your system is the valve located?
Thanks,
Handie Andie
This is the model I just installed in my new shower
http://www.americanstandard-us.com/showe...
Can I remove the pressure balancing unit without removing everything?
