Optimus lab 1100 Turntable won't turn!
The Turntable is belt driven, fully automatic.
My problem is press the play button, arm lifts, turntable moving Ok then just as the arm drops over the LP the whole movement stops, turnbale including. what have I done wrong. The belt is Ok. Is there some movement somewhere I can fix??? The turntable plinth will come off OK. and vbelt is iasy to put on or take off. Help.
    Problem Solver:
  • 5 Answers
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Posted on Sep 18, 2008
My jensen three speed turntable is not spinning my record
If it is a belt driven model it might have fallen off. If you lift up the turntable matt it should show a hole to view the belt. If the belt is good, it could be that a switch is not engaging when the arm moves out to the record, if it is the type that starts when the arm is placed on the record.
Mar 09, 2016 | Jensen Audio Players & Recorders
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
Haven't used the turntable in years. Went to use it today and the turntable doesn't begin turning when the arm is lifted. Everything else works. Thanks, Al
If this is a belt driven turntable, then you have to replace the belt, as this units gets old the belts loosen up as well.
Aug 20, 2010 | Crosley CR74 Turntable
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
1,135 people viewed this question
 Grubhead
Grubhead
