About all you can do is clean it up, wire brush any corrosion, check the batteries, wires and make sure it is in good and tight to make it grounded. If it still won't work after that then you will need to replace it. Thses are very common in all the hardware stores, the are also not expensive to buy. IOf your not using the rotissary lighter, then just swap them out.
Some of these grills came with a battery operated spark igniter, try to screw of the button part of the clicker of the top. If your has this type it will unscrew and you will see a battery there to replace. IF not you will need to buy a new one and try to find the battery opp. one they will last longer. Not a serviceable part if it has quit working other than replace it.
