Question about Video Game Consoles & Games
Hi my problem is that my psp battery pack it does not fit into battery holder and as soon as i turn it on it turns off when on loading screen the batery is fully charged would i be able to buy a new battery pack that will fit
  • 586 Answers
You have to buy bettary from any recomanded SONY DISPLAY shop.From where you can get the orignal one.
Posted on Aug 07, 2008
SOURCE:
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Hi i want to ask how to downgarde psp 6.20 to 5.50 without pandora battery please help me in that...thank you
Hi
You can downgrade your psp without a pandora battery but you will need a Lumines game hack,Follow these steps to do so.
Download the 5.50.pbp file. Rename the 5.50.pbp file to "UPDATE.PBP." Connect your PSP to your computer with the USB cable and select "USB Connection" to place the PSP into USB mode. A window will appear on your computer and you will be able to see the PSP memory stick files.
Download the downgrade pack. Open the "MS_ROOT" folder from the downgrade pack. Right-click the "PSP" folder and click "Copy." Go back to the PSP memory stick and right-click it. Click "Paste" and "Yes" to overwrite the data.
Right-click the UPDATE.PBP file that you downloaded in step one and click "Copy." Open the "PSP" folder on the PSP memory stick and you will see the "GAME" folder. Open this folder to reveal the "UPDATE" folder. Right-click the "UPDATE" folder and click "Paste" to transfer the update file to your PSP memory stick. The downgrade pack and 5.50 update file are on the PSP memory stick. Press the "O" button to safely disconnect the PSP from your computer.
Insert the Lumines PSP game into the PSP drive. Select the game from the PSP menu to start. Press the "Start" button when you get to the Lumines start screen. Your screen will blink red and will turn completely blue. You will be brought back to the PSP screen. It is important to not press any buttons before you get to the Lumines start screen.
Go to the game section of the PSP menu and you will now be able to see the "x.yz update" application. Select it with the "X" button to start it. Press the "X button from the main menu to start the downgrading process. Press "X" again to reboot the PSP when the downgrade has completed. You have now downgraded your PSP to 5.50 firmware.
Jul 31, 2010 | Video Game Consoles & Games
PSP BLANK SCREEN
Hows the battery? need to be charged?
possible battery pack is old.may need to be replaced.
Jan 12, 2010 | Sony PlayStation Portable (PSP) Console
Problem loading the NEW PSP ACTION REPLAY.
TADA! answer 4 u.
It's your battery. Take out your battery from the psp and look on the back of it. If, at the top, it says PSP-S110 and at the bottom it says made in China, be bummed. That's what mine said and the codejunkies website warns about that battery. Dunno where to get a new one though. Hey, diagnosing the problem is half the battle. Good luck.
Dec 03, 2008 | Video Game Consoles & Games
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    PSP Will not start
    What hapenned to all your PSP's is that they 'bricked'. When your PSP is installing an update and you interrupt the process, the data where the PSP's operating system (=firmware) is stored got corrupted (=broken). In very rare cases this can happen when you play a game and something goes wrong due that game. When your PSP is bricked the green lamp is on but the screen stays black.
    Now straight to the point..The solutions:
    1.If your PSP 'bricked' because you interrupted a system update (Powered off while updating, canceling update..), then you can only help it by re-installing the firmware correctly. NOTE: This is unsupported by Sony and is something you do on your own risk, for a usual PSP user it is a complicated process and i suggest you should let someone with experience do it. If you still want to attempt it, for example here's a tutorial for making a 'pandora battery' : http://www.youtube.com/watch?v=ZKFnuCfTPZo
    To find more information about this subject you could seach on google for tags like 'psp pandora mod custom firmware jigkick'
    2. If your PSP suddenly doesn't start up after or while you played a game, then you have a chance that you can recover your PSP without too much hassle. Simply let your battery run empty. After it's empty, remove the battery and let your PSP 'rest' a day without battery. After that, reinsert the battery, first fully charge it, and THEN start your PSP up (after your battery is fully recharged). If you have luck you might have your PSP working again.
    3. Contact Sony and explain the situation. Explain that you did nothing wrong. If your PSP is still under warranty they should help you..
    Good luck and if i helped you please leave feedback! Thanks
    Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
    Psp turning off while playing
    Check the battery holder.Sometimes the battery holder can cause that problem.If you replaced your battery door make sure the new one have a little pad inside or the battery can get loose.
    If this one don`t solve your problem try to upgrade the firmware.May be is a bug in the Firmware
    Jun 14, 2008 | Sony PlayStation Portable (PSP) Console
    My screen wont turn on
    u have a failed reader chip or a dead screen! return the device as soon as u can remember u a actually don't need a slip for proof of purchase! the store generally must have record of transactions, just have the date and time of purchase and they by LAW must have a record of it. so get it swapped over
    Jan 31, 2008 | Sony PlayStation Portable (PSP) Console
    Wont turn on
    this is a common problem, sony could help with this but its alot of hassle, call them anyway. if you have the receipt you can return to place of purchase. this is a glitched psp. you prpbably tried upgrading and then this happen or it just happened
    Jan 13, 2008 | Sony PlayStation Portable (PSP) Console
    PSP will not light up when turned on.
    You have what is known as a "brick." It is caused by a PSP being improperly turned off in the middle of the update.
    When it's coming up with that black screen, it's trying to load but failing to get the OS loaded correctly, which is what is causing the problem.
    Your firmware needs to be re-flashed. Fortunately, this CAN be done.
    What you'll need:
    - A spare memory card (64MB size should be sufficient).
    - A spare PSP battery to turn into a Pandora (service mode) battery
    - A friend with a working PSP and custom firmware loaded.
    More info (and the Pandora creation files) here:
    http://dl.qj.net/Pandora-s-Battery-PSP-Homebrew-Applications/pg/12/fid/14362/catid/151
    Tutorial on how to do it:
    http://pspupdates.qj.net/Tutorial-How-to-unbrick-your-PSP-via-Pandora-Battery/pg/49/aid/100693
    Nov 13, 2007 | Video Game Consoles & Games
    Video Game Consoles & Games Logo
    21 people viewed this question
    Top Video Game Consoles & Games Experts
    Ekse
    Marvin
    Marvin
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
