Question about Dell 1710 Laser Printer
1710 Printer Paper Jam light on, no paper jam found, tried resetting nothing seems to shift the problem
The problem in my case was not fixable, the small switch sensor inside the printer had broken free, the engineer's informed me that it would cost far more to fix the problem than it would to buy a new printer.
Anyone want 2 boxed toner cartridges for a Dell 1710 printer?
Posted on Aug 08, 2008
SOURCE:
Paper jam light is on
Look real close. It is difficult to see very small pieces of paper that coudl be lodged in many areas. Also if you take a clean cloth with a little rubbing alchol and clean the sensors, this may help
Jun 17, 2010 | Dell 1710 Laser Printer
Online error light nothing prints
I have a ML 1710 .Not my area of expertise but I took out the paper and could not see a jam. Took toner out , a little cleaning, plugged and unplugged from computer several times. I found paper jammed in the very back ,folded so tight nothing was showing. Mine has a back door and the paper is having trouble rounding the last bend and coming out. So I leave the back door open to get my copies. Green light on.
Feb 26, 2010 | Samsung ML 2010 Laser Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Dell 1710 paper jam
Next time don't buy Dell. That's the solution.
Oct 05, 2008 | Dell 1710n Laser Printer
"Paper Jam"
Your printer is still trying to print whatever preceded the paper jam. Go to Settings/Printers/your printer/ and clear all documents in the printer que. You will also have to shut down the printer and restart the computer after this to be sure.
qwester
Aug 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Printer says it is jammed
unplug printer from wall for 12 secs and plug back in
Jan 15, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Dec 12, 2007 | Dell 1710 Laser Printer
Paper jam
Just for sharing,
Yesterday i got same phenomenom. After i check , i found the root couse came from, printer head (PG-40) is hit foreign part in the left side when printer is initialize. So the home posistion of head become shift to right. So when the head move to right in parking area, become hit stopper of waste ink platen, that impact to mechanism of paper feeder.
After the foreign part is removed, my printer can work normally.
Sep 26, 2007 | Canon PIXMA iP1600 Printer
Dell 1710 Laser Printer Logo
519 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
