Question about Apple iPod nano
My Computer and iTunes does not recognize my iPod
I connect my iPod to my computer and neither iTunes nor my computer recognizes my iPod. My iPod will start to charge but the battery meter varies greatly. Both my computer and iTunes recognize my wife's 30gb video and her sister’s 2gb nano when connected. Can you please help me? my computer dont see my ipod
  • 3 Answers
Restart your ipod then the ipod will be start
Posted on Aug 07, 2008
SOURCE:
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
Jan 24, 2013 | Apple iPod classic MP3 Player
ITunes will not recognize my Ipod MA444LL
There are many reasons why iTunes will not recognize your iPod, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPod you have, here are a few suggestions for helping the problem of iTunes not recognizing iPod:
  1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
  2. If you are running iTunes in the latest version, but still can't get your iPod recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
  3. USB port on your computer can be another reason why iPod not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
  4. Of course, your iPod may also be the cause of iTunes not recognizing iPod. At this moment, you can restart your iPod by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPod to computer with USB cable again.
  5. You should also make sure your iPod trusts your computer, because after changing a new system on computer, your iPod will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
  6. After checking out all the aspects mentioned above, you can try to connect iPod to computer with the USB cable again.
What to Do When iTunes Not Recognizing iPhone
Dec 21, 2011 | Apple iPod Audio Players & Recorders
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
May 24, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Try the link below that applies to your computer OS:
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_3_for_Mac
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
Useful troubleshooting-video:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
Feb 27, 2009 | Apple iPod nano
sorry unless you can get it to set to factory settings then your stuck id take it to a shop or trie some one ells computer if this fails then it a fixit job
Nov 26, 2008 | Apple iPod nano 3rd Generation
Install the drivers for your ipod specified. Try changing the USB cord as next solution.
Dont forgrt to rate this
Aug 20, 2008 | Apple iPod nano
Look into the bottom of the iPod where the USB connects. Make sure none of the pins are bent and that there is no corrosion visible. Also, are you using the same cable when you connect the different devices?
Jul 31, 2008 | Apple iPod nano
does other computers recognise your ipod - menial remedy but try resetting it hold down menu and play buttons till u see apple icon then connect........basic but maybe
Apr 19, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
226 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
