Question about Hampton Bay 24002 Ceiling Fan
I have a 2 speed fan than hums what could I do to fix this problem?
  • 876 Answers
Go to this site for your answer. I read through it and would try to explain here but there are several areas in the fan that could be causing the problems and you can print this page off to help you. It seems to be a common problem, so take heart! I believe you will find your solution here. Good Luck!
http://www.ceiling-fans-n-more.com/ceiling-fan-general-troubleshooting-and-FAQ.php#6
Posted on Aug 07, 2008
I have a 3 speed fan controlled by 3 speed wall switch; fan hums on low, louder hum on medium, and high position eliminates hum but speed reduced to low. Is it the fan or the wall switch?
Check the capacitor (black box with wires going to switch) and see if that's going bad. If it's not that, take the control out of the wall and just use the pull chain to see if it runs correctly. If it does, you need a new wall control. DO NOT USE A DIMMER SWITCH!
Aug 04, 2014 | Concord Fans PB-1032-ORB ARACRUZ Oil...
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
DS 1910
Hey Anon,
You will probably spend more on trying to fix this than just BUYING A NEW ONE!!!! https://www.walmart.com/browse/home-improvement/pedestal-fans/1072864_133032_1230511_1230520
Jun 19, 2017 | Duracraft Dryers
My Hampton Bay runs too slow on high speed and makes slight hum.
hello,
the fan could have a weak coil that is ability to run fast or the capacitor is leaky, if found to be bad replace with a new one of the same rating..
Hope this will help...
May 31, 2010 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Fan hums when turned on - not when lights are on - only when fan is on - raher loud
On high speeds, they usually do. They have like a vibration sound to them. Have you tried each speed on the fan. With the lights, you're not going to get a humming sound. Only when the fan is on. And yes, usually at the higher speeds (3 speed fan), they do seem pretty loud. I'd have a family member or friend listen and get their feedback before contemplating changing it. Feel free to contact me back with your feedback, and I can help you from there. Good Luck, and I hope this works out for you. - Jim
Mar 25, 2010 | Hampton Bay 52 In.Carriage House II in...
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Hampton bay fan noise
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Jun 14, 2008 | Hampton Bay 24002 Ceiling Fan
Celing fan making noise, how to oil
HOWEVER...
Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
116 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
