Question about HP Officejet 5610 All-In-One InkJet Printer
Calibration strip location
I had to pull my HP Officejet 5610 apart and a little white strip came out. It is white plastic, 9" long, 1/2"wide, 0.035" thick. It has a little section sticking out labeled:
PLATE-CALIBRATION, plus the identifiers:
JB61-00305A >HIPS< #2-3
When I put the 5610 back together I didn't know where this strip went and left it out. Now the 5610 doesn't work right and I need to know where the strip goes. If you have a 5610 to look at maybe you can tell me or take a digital picture and email it to me at kenrogera@yahoo.com.
Thanks, Ken Rogers
I got my answer from a very helpful scanner expert from a posting on the newsgroup comp.periphs.scanners. The plastic piece went near the end of the bezel that holds the glass above the starting position for the scanning run. Once I knew the idea, locating where it went was easy because of small indentations in the bezel the shape and size of the plastic piece. Thanks.
Posted on Aug 08, 2008
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
J un probleme avec mon hp officejet 5610 il
Hi There
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 12, 2010 | HP Officejet 5610 All-In-One InkJet...
When i scan my documents in the document feader i get a line on the scaned document
Look on the narrow glass under the feeder, a scratch or spot of white-out will make that streak. Also wipe the white bar above the glass and power down and back up so it can calibrate to the clean glass.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
I accidently pulled out a piece of white strip with tow blue ends. Now my printer wont turn on....I took it apart but don't know where this white strip goes...
Sounds like the encoder strip. There's a hook on one side, itgoes through a slot in the printhead, near the top in the back, and a spring to hook it on the other side. Hard to put back without taking the covers off.
Jul 03, 2009 | HP Officejet 5510xi Printer
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
