Sony KV-14LT1U tv, 11 blinks won't switch on - Televison & Video
  • v_g_t Dec 25, 2008
    I have the same problem with SONY 29" Trinitron
  • 10,594 Answers
IC001 seems in problem and TV gives 11 time blinks error signal. Please check IC001 in your 14" Sony TV.
Posted on Aug 07, 2008
My tv won't turn on it blinks and doesn't turn on
Check this site to get more details about blinking codes to Sony TVs. Pull up older posts there. Count the number of blinks occur at one time switch ON, before you continue. These pre-set number of blinks are fault indications.
Mar 31, 2013 | Televison & Video
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I have a sony TV model KV-28ls36u, the problem was, when power is turned-ON, the LED blinks 11 times, what would be the best solution for this and where can I get a service Manual. Please help. Thanks
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 to Rs.600 - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service
Apr 09, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony trinton 27inch red light blinks 11 times
those LED flashhing codeds are useless. You most likely have a problem in the high voltage circuits. You should bring that one to a local shop as it's very nlikely you can fix it yourself, and the high voltage circuits are dangerous.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby/Timer LED blinking
These unit are famous for the PCB Print to be cracked around the HV Circuit and or the Horizontal Drive Transformer pins needing to be resoldered. It can turn into a very Major repair if the HV Components short. In that case the Power Supply will also short out.
Hope this helps
Skyassoc
Jul 04, 2009 | Sony KV-32S42 32" TV
Sony tv no pic or sound
Sony error codes usually only go up to 7. If the LED blinks 11 times, this usually indicates that either the clock or data line is shorted and this needs to be serviced by someone with experience with Sony sets.
Jun 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
252 people viewed this question
Top Televison & Video Experts
Electro Med Services...
