Question about Dishwashers
My GE dishwasher after complete washed look like water not out drain (water remain in the tub)
  • 706 Answers
Normally, there is a filter that precedes the pump and that's probably clogged with food by products. Look for the filter screen near the bottom of your dishwasher and remove any debris there.
Another consideration is if your dishwasher drains into/ through your garbage disposal... If so.. make sure that is empty and drains properly when you run the water in the sink. Hope that helps....
Posted on Aug 08, 2008
Dirty water standing in the bottom of the tub
There is probably some debris that is blocking the water from getting to the pump.For More information please visit Kenmore Parts.
Oct 04, 2012 | GE Nautilus 24" Built-in Dishwasher
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
WATER WILL NOT PUMP OUT OF MACHINE
Here are some solutions for GE built dishwasher when water will not pump out of machine:
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Jun 10, 2011 | GE 24 in. GSD3960LSS Stainless Steel...
Water in bottom of GE Nautilus dishwasher
I was having the same problem and downloaded a copy of the manual and found out it is normal for a couple of inches to remain in the tub! I can't remember where I downloaded the manual, but you can "Google" it like I did. Hope this helps :o)
May 15, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher stopped draining after cycle
Some water always remains in the bottom of the DW (al least with most DW) but here is some help....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Jan 07, 2009 | GE Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | GE 24 in. GSD4060JSS Built-in Dishwasher
Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Jan 25, 2007 | GE 24 in. GSD1000G Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Dishwashers Experts
