Question about Dewalt 7.2-18.0 Volt One Hour Charger
De walt de9118 charger
I have a 240volt charger; when plugged in the red light comes on then goes off.There is 54volts dc at the battery terminals which troubles me. any suggestions,thanks
    Champion:
  • 313 Answers
When charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Posted on Aug 08, 2008
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Hitachi cordless drill charger not working
The various rates of flashing are error indicator codes and should be explained on the charger case. They are for the condition of the battery's though and not the charger. It sounds like the charger itself is bad. Can you return it for a replacement? Is it still in Warranty? For whats its worth, I went from Milwaukee tools to Bosch to De Walt before being satisfied with performance. I hope this helps.
Dec 14, 2013 | Hitachi UC18YRL Universal Charger for...
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
Battery #1 terminal lights red and stays red.
Disconnect the - lead from that battery, Repower the charger. The LED should be green. If it stays RED, charger defective.
Reconnect the - lead to the battery, measure voltage when charger is on. Should be between 11.5 and 13 volts. If OK, replace the battery. If lower than 11.5, check for charger cable connections OR for a connected load ( power drawing ) of more than 10 amps.
Sep 20, 2017 | Guest 2631a 30 Amp Battery Charger
Generac 10 k battery charger installation at the generator, where does the ac input wires connect
Your electrician should have run a set of wires out to the generator from the transfer switch. The unit actually comes with a fuse holder, fuse, terminal connector, and jumper wire for installing these wires to the t1 or t2 terminals in the transfer switch. The dc wires will be the ones coming out of the battery charger, 1 of them will have a red marker around it, that is your dc positive. The 2 wires coming out of the opposite side of the battery charger is actuall your ac connection.
hope this helps let me know.
Nov 01, 2009 | Guardian Electrical Supplies
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
How do i connect a battery charger
I suppose this is what you want to know
The battery charger has 2 leads coming off it as well as the power lead to the external power source .THE TWO LEADS WITH CLAMPS ON GO TO THE BATTERY THE RED GOES TO THE POSITIVE TERMINAL PLUS SIGN AND THE BLACK GOES TO THE NEGATIVE TERMINAL.MINUS SIGN, THE POWER LEAD PLUGS INTO THE POWER. AND THAT IS ALL THERE IS TO IT..
Sep 10, 2009 | 2002 Mitsubishi Lancer
Inspiron 1521 adapter vs battery
take an ohm meter you can buy for ten bucks at radio shack put the volt meter on DC volts plug the charger into the battery charger end the black lead goes tothe outside and the red goes inside, set the meter for 12 volts dv and mesure the voltage. read the voltage output on the battery charger transformer see if it's within a half volt if not the charger is bad, if it's ok then use rubbing achol and a q tip to clean the battery connectors on the computer and the battery itself, if you do not get the light then pull the battery out and hold the power button in the on postion and hold the enter key for 1 minute and try again, if the lights do not come back on your battery is dead, if the computer will still boot with the battery then the charger is working if it won't boot up the battery is dead. Got it?
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Dewalt 7.2-18.0 Volt One Hour Charger Logo
1,465 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
