Question about Samsung SF 5100P Laser Printer
Ricoh Fax 1140L
I have a problem on my fax there is message on display "Printer Error Fuser Temp." can someone help me how can i reset these trouble code?
thanks Abihailjeana
  • 1 more comment
  • Christopher Pielago
    Christopher Pielago Aug 07, 2008
    thanks Abihailjeana
    I have a problem on my fax there is message on display "Printer Error Fuser Temp." I already check the hardware Heater Lamp, Thermistor, Thermostat, all are ok and Good. Can someone help me how can i reset these trouble code?
    thanks Abihailjeana
  • Kraisorn
    Kraisorn May 05, 2014
    I have a problem on my fax there is message on display "envelope picture" on the screen. Can someone help me how can i reset these trouble code?
  • Samsung Master
  • 2,794 Answers
The only reset there is for it is to turn it off, wait 30 seconds, and turn it back on again. If it appears again, it needs service in case the thermistor needs to be replaced or something else.
Posted on Aug 07, 2008
  • 4 more comments
  • Tim Babcock
    Tim Babcock Aug 07, 2008
    As far as I know Richo doesn't have a service code to reset fuser errors probably for safety reasons. If you can get a hold of another thermistor you might just want to add it. That should take care of it.
  • Tim Babcock
    Copytechnet.com is staffed by Ricoh technicians you might want to check with them on that website.
  • Tim Babcock
    Hey abihailjeana you got some good questions on some products that you might want to go to another forum like copytechnet.com and get answered. They have trained technicians on product lines that can help you out better than this forum. This is more of site for end user questions and answers and not tehnician to technician questions.
  • Abhilash Apr 23, 2011
    press the following keys:
    1. DOWN ARROW, *, #
    2.press OK
    3.press the #1 key and then OK
    4. press stop
    5. press the DOWN ARROW, #, then the UP ARROW key( machine will display T-PRINTER ERROR)
    6. press OK then reboot
  • waqas zafar
    waqas zafar Feb 09, 2014
    Abhilash's solution works perfect thanks Abhilahs..
  • abdelrazekaz May 12, 2014
    very good
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
Drivers for my printer ricoh fax 1140L
hello i have a question, is ricoh 1140L a printer also?
Mar 01, 2011 | Ricoh Office Equipment & Supplies
Hello, I have a fax machine which is for business use and used daily throughtout the day, we have a problem, the fax machine is a RICOH Fax 1140L. There is an error on the screen sayinh 'Printer Error...
There is not much that can be done from the outside as your fax is showing an error due to a failure in the system circuit. Best that can be tried is to remove paper, clean the head with a soft cloth clean the paper insert section. Put the fax on and if the fault message comes on again, you will need to open out the set to probe into the main board. remove back panel and reinsert all connectors , If there is no result, you will require help so that we do not tamper much. Good day
Aug 14, 2010 | Computers & Internet
How can ib reset e`rror code of ricoh fax 1140l (printer error fuser temp)
Sir,
this error usually ocurs when you towner is empty or have completed is age.But as you said error fuser temp this might be that you priner buffer has got damaged while it repaire able bus is expncive so I would rather suggested to buy new one printer and Canon and HP are the best brand in my dictionary so you can try one of them.
Nov 08, 2009 | Samsung SF 5100P Laser Printer
Fax confirmation with copy of 1st page
what is the error code 05 for ricoh fax 1140L?
Jul 21, 2009 | Ricoh FAX1180L Laser Fax
Samsung SF 5100P Laser Printer Logo
1,807 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
