Question about HP Color LaserJet 2600n Printer
2600n can reset chip
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
??????????????????????????what chip???????????????????
Posted on Aug 07, 2008
10.1002 supply error
refers to an error on the Yellow cartridge; Yellow is designated as "02". there is a memory chip failure or memory chip missing on the yellow cartridge.
Dec 26, 2012 | HP Color LaserJet 2600n Printer
When I open the toolbox for the LaserJet 2600n printer, it tells the website is not available. I need to clean the jets etc.
You need not to clean laser printer cartridges,it may color or mono. Print cartridges them selves having cleaning blade to clean the surface of the OPC drum every time when its initializing or printing. If you found any vertical tracks on print outs replace the particular cartridge.. If you have any kind of print quality issue,perform calibrate process through printer menu..quality..calibrating.. even if you found quality issue clean the Laser scanner assm.(professionals only can do)
Oct 28, 2011 | HP Color LaserJet 2600n Printer
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
I refill toner but the machine inform toner incorrec
These cartridges have a chip on them that must be replaced. Most reputable vendors of toner will tell you this and sell you the correct chip.
May 27, 2011 | HP Color LaserJet 2600n Printer
How to reset hP 2600 colour printer chip
When you refill an HP color laser cartridge you need to replace the SmartChip, as I do not believe that there is any way to reset the chip. Any reputable seller of toner would include the chip with the toner order. The are for sale on Ebay
Apr 11, 2011 | HP Color LaserJet 2600n Printer
Magenta color problem
This can be caused by one color not printing ...either from the lack of toner or the cartridge not being seen as full ..To reset them follow this procedure..
This will override the toner level in the cartrdges and allow it to print all colors..and probably get rid of teh problem ..Usually the magenta predominant printing is caused by the lack of yellow color ..so watch it cause this one might empty first and cause it again if this procedure fix it for now ..There is a possibility that it is already out ..(empty )
Jan 28, 2011 | HP Color LaserJet 2600n Printer
I am trying to reinstall the black ink cartridge to a hp2605dn and it keeps saying the error 10.1000
I found this info on the web for you, guessing you are using a recycled or generic cartridge:
The HP LaserJet 2300 toner cartridge has a smart chip on the top left side. This chip tells the printer when the toner is low.
Recycled toners do not or can not reset the chip, therefore when you use a recycled toner you may get toner low messages although the toner is good.
Also, you may get the 10.10.00 error. There is a work around to fool the printer into not displaying the message.
Place a strip of opaque tape or paper on the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
No guarantees but it seems plausible.
Jun 19, 2009 | HP Color LaserJet 2600n Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Hp couler laserjet 2600n
There is a chip on the cartridge that is bad or missing. If this an after market cartridge this a common error with the chips. You either need to return the cartridge or find someone that sells the chips fot the cartridge.
Jan 06, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
201 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
