Question about Nintendo DS Lite Console
Ds lite top screen problem
While playing the top screen goes white/ to resolve this i have to flip it down and open and the screen is working again . this can happen several times during any game.
  • 25 Answers
My ds has the same problem, except it stays white! but only because the cords on the left side of the ds (bust the part where the two light indicators are, power and charging, and slide the top screen to the right, then you should see the cords.) are not connected ore are lose from the central part of the ds. Ask nintendo or somebody who is a whire repairer to connect these wires.
Posted on Nov 30, 2008
Screen flashes white then goes black
Sounds like a ribbon cable to the top screen maybe damaged. Upon startup, the ds does a systems check, any kind of failure e.g. a ribbon cable or a faulty screen would cause the console to shut down again. Presuming everything else works charging etc this is most likely to be the problem.
Sep 10, 2012 | Nintendo DS Lite Console
When I turn my Nintendo DS Lite on, the touch screen works fine but the top screen just goes plain white. I've tried turning it on and off but that didn't work. The screen is just white and that...
sounds like It is broken.
unless you get the startup screen beefore it goes out white i'd say something was damaged in the screen or the wiring connecting the screen to the unit.
If you see any lines on it, It was most likely over extended open and the wires inside have become frayed or damaged. If you try fully opening the top screen and push inward you may have temporary relief of this issue. could try puling out also but either way this would just be to test if thats the issue. dont pull or puch to hard as you could damage the unit further.
if it is a pure white screen the screen may have cracked or had something spilled on it which would damage the screen beyond use.
Either way, the system is damaged and needs to be replaced or repaired. Price wise it is more advisable to just buy a new unit rather then purchase parts and repair it.
Jul 02, 2011 | Nintendo DS Lite Console
DS Lite wont power up, just flickers and goes out
ur problem with top screen.the strip may be damaged change the top screen .
Aug 29, 2009 | Nintendo DS Lite Console
Screen goes completely white when I try and play any game.
I am prettty sure you can not fix that or maybe your lamp inside the ds is broken im not expert on a ds but im pretty sure it cant be fixed
May 25, 2009 | Nintendo DS Lite Console
Top screen goes opaque white, but looks fine with pressed L button.
Puchigusu,
You have a defective flatcable of the upper screen, or the calble is not correct seated in the connector on the systemboard.
The upper screen connector is on the bottom side of the Left button-switch.
If the flatcable is defective (most likely because of the open-close actions every time the DS Lite is used) you have to replace the complete upper screen (the cable cannot be removed without replacing the whole screen).
First try to reseat the flatcable in the connector. If that is not working, replace the screen (manuals how to open the DS Lite etc etc can be found on the Internet)
John
Oct 31, 2008 | Nintendo DS Lite Console
Blank white screen
Try using some alcohol to clean the contacts of the card and leave some on and reinsert a few times - leave to evaporate and try again - sounds like dirty contacts!
Sep 16, 2008 | Nintendo DS Lite Console
Nintendo Ds Lite White Screen
Try cleaning the game. If you look at it in the light you may find it has some scratches or something. You see my brother has that! Love Tamsin
Mar 15, 2008 | Nintendo DS Lite Console
Nintendo ds lite,green light on but not the screens
I had the Same problem on my wifes DS.  First problem was that it kept swithing itself off, so sent it to Nintendo for repair.  Within a week it was broken again.
This time the green light was coming on, but no sound and no sign of life in the screens.
Well, I'd already had to pay nintendo for the first fix (different region, no warranty, apparrently).  So I thought seeing as it's out of warranty anyway, why not open it up and have a look.
To open it you need specailist tools, I don't recommend it if you've never done anything like it before.
Anyways, the bios chip was no longer connected to the main PCB.  I simply plugged it back in and added some slips of post it note to stop it coming off again.
You can see in the picture, the chip easily plugs back onto that white clip on the board.
Once it was back on. the DS has been working fine.
Feb 27, 2008 | Nintendo DS Lite Console
Ds lite
Looks like you left a loose wire or flexible ribbon cable, open the unit again and be sure the cables are well locked into the connectors, be sure the flexibles are in good conditions and over all check the screens or other metallic parts not to cause a short circuit.
Some metallic parts have electric tape isolations to avoid them to touch the circuit board and fry the DS for example when you press a button amd make pressure over the parts.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
My nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Nov 17, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
106 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
