Question about Venturer Televison & Video
My venturer pvs6100w dvd player will turn on to a blue screen but when i put in a dvd or cd it doesnt do anything
4 Suggested Answers
SOURCE: All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
Posted on Dec 20, 2008
ishwarnotani
  • 13 Answers
SOURCE: connect ps2 to my Venturer 8'' portable dvd player
CHANGE THE CONNETING CABLE
Posted on Feb 05, 2009
nandosnut
  • 112 Answers
SOURCE: the cd is working fine. however there is no display on tv.
Ensure that your connections are securely in place; a loose cable can cause signal loss and yet may not be totally obvious from a qick inspection.
HTH.
Posted on Apr 20, 2009
I have a Venturer PVS 7287 dual player. The player we use most will play the sound but the screen is a blank white. We've tried different DVD'S with the same results.
Venturer PVS7287 Twin Mobile DVD Player 8" LDC Screens - I was getting a blue screen with the DVD not loading. I could see the ribbon cable was just slightly off from the side of the optic eye board. I gently pushed it back on with the tip of a screwdriver. I didn't have to take the player apart, as you you can see the optic eye and the cable that attaches to it when the door is open and the DVD removed. Be careful with the ribbon cable, it is very thin.
Apr 14, 2011 | Car Audio & Video
One screen is blue but the DVD will play you can hear the movie but no picture on the screen
open the cover the dvd player,try to check connector from mother board thru lcd,if loosed connctor.
Mar 11, 2010 | Power Voice System Venturer 7" Portable...
My radio comes on and everything works but the screen doesnt come
You can check your power cable for DVD panel,put down it then connect the power one more time.I think the panel's questions.
Sep 04, 2009 | Dual XDVD8181 Car Video Player
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Help with venturer pvs6100w
i had the same problem. there is a switch that gets pushed down and there is something sticking on the back of the screen. i put layers of tape on it to build it up to push it down further to fix it. can also try to stick something where the switch is but you will need to turn it off to switch discs. if you really know what you are doing you can try and take it apart and try and fix it right.
Sep 09, 2008 | Venturer PVS1950D Car DVD Player
Venturer PVS6281 - Playing One Disc on Both?
the red, yellow,white cables connect them to both of the dvd players.One of them the little switch on the side put one on dvd and the other one on av in. then put a dvd in one and play it. (make sure both are on)
Jun 14, 2008 | Venturer PVS62911 Car Video Player
DVD not recognized
after loading it say no ddisc
Mar 20, 2007 | Venturer PVS177W Portable DVD Player
Televison & Video Logo
134 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
