Question about Lexmark C720 Laser Printer
Lexmark C720 grinding noise under top cover
We just replaced our yellow toner cart, and now during warm up and printing, we get a buzzing sound that seems to be coming from under the top cover. I inspected all of the gears that are visible to me for binding and they all pass. I removed and reseated toner carts, photo developer cart, and fuser unit. During recycle after top lid is closed, there are two short buzzes, followed by two longer and faster buzzes.
  • 1 more comment
  • lionelbob Aug 07, 2008
    The toner gears turn, I don't know of it can be described as freely, it takes a good twist to get it moving. But I compared the 'twist' to the two other carts that I did not change and it seemed similar. They do not 'freewheel', but they do move. We got two Lexmark brand yellow carts new at Officemax, and they both turn the same way.
    Thanks, Bob
  • buBBles8 Sep 16, 2008
    I was also getting that horrible noise as described. After reading your post, I switched out the black toner cartridge that I recently put in with an older one and the noise disappeared.  Gear on the problem cartridge does not turn. Is there any way to fix it? I would hate to waste the cartridge since they are expensive.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Sometimes the gears on the cartridges get bound up in the auger area. Do those gears turn freely on the new cartridge that you just replaced?
SOURCE: 83 PHOTODEV CART MISSING
To specify which supply has been replaced:
  1. Make sure the printer is on and the Ready message is displayed.
  2. Press and release Menu until you see Supplies Menu, and then press Select.
  3. Press and release Menu until you see Replace Supplies, and then press Select.
  4. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  5. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  6. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  7. Press and release Return until the printer returns to the Ready state.
Posted on Feb 27, 2008
SOURCE: Canon imagePROGRAF W6200
To reset the 'MT CARTRIDGE FULL SOON' error.
Enter Service mode Hold down the paper source and online button at the same time, hit the power button once.Continue to hold down the paper and online buttons until you see the printer name "Canon W6200" on the printers LCD display, then release the two buttons.The printer will initialize & enter service mode.
In service mode, scroll sideways until you see the 'Initialize' menu, scroll down to 'W-ink', and press enter. At this point I did something (scroll sideways and hit enter I think) and it came up with 'New W-ink Cart' Hit Enter to get '=New W-ink Cart' and Online to Accept. I powered down and back up, error all clear.
Posted on Jul 17, 2008
mickspaceNET
  • 115 Answers
SOURCE: Lexmark C720 grinding noise & fuser damage
From the site of your Picture, you need a new fuser unit.
The coasting is peeling off... that is not good. And I will bet you get allot of paper jams.
To replace the fusing unit is not hard to do. For the most part taking the covers off the machine and getting them back on is the hard part... Let the fuser unit cool down before you touch it..
Just remember to unplug the machine, Electronic Static Discharge is not good for the Boards in it, touch the metal chassis before you touch the boards if you don’t have a wrist strap) get your self a table and some room to work and take your time.
Take the toner cartridges out
I would do a maintenance kit while I had it apart. (rollers, transfer rollers etc)
Vacuum it out; clean it while you have it open.
(Warning toner and developer is very fine, you might need a vacuum with a micro filter on it, other wise it might go every where)
The service Manual has details on how to do all this. If you follow that you should be ok.
You could try to get all the parts to Fix the fuser unit, but it is easier and faster, cheaper to replace the whole thing. Some places offer a core exchange.
If you need any assistance let me know...
This is from Lexmark
http://www.lexmark.com/lexmark/product/home/605/0,6970,204816596_846034106_306769501_en,00.html?tabId=1
These are various other places that offer parts and supplies.
http://www.innovone.com/~tsa/
http://www.all-laser.com
http://www.p2gcentral.com
http://www.precisionroller.com
Posted on Oct 27, 2008
cq92
  • 184 Answers
SOURCE: Xerox Docuprint 3290FS colour multifunction black
Xerox does not list that model at all - are you sure the model number is correct ?
It would appear that either the cartridge or fuser may be defective.
Does the machine show any error codes at all ?
Here is a user manual for a similar model 3225 that may help under the troubleshooting section :
http://www.office.xerox.com/userdoc/N3225/pdfs/UserGuide.pdf
This is where you find manuals for all Xerox products :
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_CA
Posted on Oct 29, 2009
  • 217 Answers
SOURCE: my dell 3110cn printer is
This error message indicates that the printer has failed to read information from the chip on the black printer cartridge.
This is either.
1. Black cartridge not fully pushed into place (I've been called out to a couple like this)
2. Faulty chip on the black cartridge - effectively not responding to the printer 'talking' to it.
3. Fault on the main board of the printer.
Solution
1. Push the cartridge fully home.
2,3. If you have an old black cartridge, try that. The message should change to Replace Toner, if it does, its the chip on the cartridge, if it doesn't its the printer.
Posted on Nov 24, 2010
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Error 32 - Unsupported Print Cartridge - Replaced all 4 toner carts and stil getting the error. Could a bad (siezed up) toner cart have caused one (or more) of the rollers in the front cover to shift out...
It looks like having bad (refill??)cartridges. Try original ones. The rollers are there to push the cartridge forwart in the machine on a timed moment to transfer the toner to the belt.
Oct 19, 2010 | Lexmark C720 Laser Printer
I have a TallyGenicom 8008 color laser printer which while still printing well, is making a terrible noise - a grinding worn out part noise! Any ideas how fix it or lubricate it?!
I would suspect if the printer is still printing and feeding paper OK the problem may be related to one of the toner cartridges being stiff or partially seized.
From memory I believe the most likely toner to cause the problem is the black toner (or the yellow), but you can identify which toner is causing the problem by doing the following;;
  1. Open the front cover (the one you access the toner through) after a few seconds close the cover. The printer should go through a self test.
    If the printer makes a griding noise during this self test and warm up phase this helps with identifying the cause.
  2. Open the front cover again, this time remove the top toner cartridge
  3. Close the front cover with the top toner missing
  4. Listen for the noise heard in step 1, if no noise is heard it is likely the top toner needs to be replaced.
  5. If the noise is heard with the top toner removed, replace this in the printer and remove the second toner.
  6. Again close the front cover and listen or the noise, if it is heard the problem is with the second toner.
  7. Repeat this process for the third and fourth toners to see if one of these may be causing the problem.
After you have identified which toner may be causing the problem, you may wish to try gently tapping the cartridge.
An unorthodox method of solving the problem if you are feeling brave and don't mind sweeping up toner!!!!!!!! You may wish to drop the toner cartridge (GENTLY) from waist height to the ground.
This may dislodge any toner jamming the cartridge and will resolve the problem - It will also spill a bit of toner on the ground so you have been warned!
Aug 16, 2010 | TallyGenicom 8008 Laser Printer
Will the Lexmark C720 print with only the black
There are some Lexmark color laser printers that are capable of black-only printing w/o the color cartridges installed, unfortunately, the Lexmark C720 printer is not capable of printing with only the black cartridge installed.
Jun 02, 2010 | Lexmark C720 Laser Printer
Not printing
The problem could be the Developer Clutches not turning the cartridge. Thus toner does not develop and get transferred to the photodev cart. This may be due to a missing retainer clip try replacing the clutches. That should solve the problem.
Dec 09, 2009 | Lexmark C510 Laser Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Noises when printing copies
Take the new cart. out and reinstall the old cart. Does the noise disappear? I would tap and shake the toner cart. BUT BE CAREFULL, the cart is ready to spill toner. On the box and in the instructions it tells you, or should, that you must shake and tap the outside of the cart. This is due to settling and the toner maybe packed. By tapping and shaking it will feel the toner. If the toner is packed it will put undue pressure on the augers inside the toner cart. and cause a grinding noise. If after tapping and shaking, reinstall the new cart. and check. If everything is ok -- great. If the noise remains contact the company your purchased the cart. from and ask for a replacement. These cart. are mass produced and mostly reused ( refurbed). Parts wear now and they do not replace the inside parts, they just repack with toner and seal.
Dec 25, 2008 | Sharp AL 1631 Copier
Oct 27, 2008 | Lexmark C720 Laser Printer
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Lexmark C720 Laser Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
