Question about Lexmark X2500 All-In-One Printer
A light on my computer won't shut off
There is a colored light flashing.Every time I try to use my new all in one LEXMARK X2500 it says cartridge is not compatable. I am using the same cartridges that came with my All in one printer. It won't let me print anything. It was printing fine until this light started flashing. PLEASE CAN YOU HELP ME?
  • beccasweetpe Aug 09, 2008
    i have a lexmark x2500 all in one printer and a light stays on saying i'm out of ink, but i just changed the ink with the same that came with it, and now it wont print at all. HELP
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..these happen when the printer cartridges are changed, AND the print clean/alignment are not conducted.
Posted on Aug 19, 2008
X2500 new black cartridge won't work
Try to insert a different known working or a new color cartridge to identify if it's a faulty cartridge issue. Please contact Lexmark Technical Support Center should you need further assistance.
Mar 28, 2012 | Lexmark X2500 All-In-One Printer
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
Replaced the ink cartridge and it is not printing
Try to check your ink levels. On your computer, go to Start menu > Programs > Lexmark 2500 Series folder > Lexmark Solution Center. If ink levels are substantial for printing, go to the Maintenance tab and select Clean to fix horizontal streaks. It could be due to clogs and dirt in the cartridge nozzles caused by long periods of non-usage.
If the light continues to flash for both cartridges, try to replace both cartridges with different known working cartridges or better yet, replace them with new genuine Lexmark supplies.
Dec 05, 2011 | Lexmark X2500 All-In-One Printer
My new color store bought cartridge is not being recognized as full on my printer #29 for x2500 Lexmark rpinter.
Make sure you are inserting a genuine Lexmark cartridge.
It could be a slight communication problem between your cartridge and your printer. Try to remove the cartridges from your printer > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, reinsert the cartridges.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark X2500 All-In-One Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    I get an error message on my Lexmark X2500 All in One that there's a problem with the ink cartridge. As instructed I removed and re-installed the cartridges. I have also cleaned the connectors with a damp...
    Hello. It seems that you have a mechanical/hardware problem in the printer itself. Remove the cartridges from the printer. Unplug the printer from the power source. Plug it back to the power source after 10-15 seconds. When the printer's ready, insert the cartridges and make sure the cartridges are properly seated and locked in the carrier. Make sure there's no foreign objects blocking the carrier. Close the cover. Let it print the alignment page all the way through without cancelling it. If it still makes the banging/knocking sound, I would advise you to call Lexmark. That is a sound of a defective printer already. Good luck!
    Apr 10, 2010 | Lexmark X2500 All-In-One Printer
    Lexmark printer always want a new cartridge
    What you need is to reset the ink level:
    1) Goto the Lexmark Solution Center application.
    2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
    Hope this help.
    YBC (/\)
    May 28, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark x2500
    Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
    Mar 25, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark printer X2500
    there is no communication from computer to printer
    Dec 28, 2007 | Lexmark X2500 All-In-One Printer
    Lexmark X2500
    1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
    2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts) while installing the carts choose the option "new carts"
    Leme know if this has helped u
    Dec 08, 2007 | Lexmark All-in-One Printer with PictBridge
    Lexmark X2500 All-In-One Printer Logo
    78 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Sanath Kumar V
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
